Restricting oil to rockers on -1s, necessary? how? #182317
01/03/09 10:31 AM
01/03/09 10:31 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'm sure this has been discussed before but I'm not having any luck searching so I thought I'd ask again.
Put on a set of Indy -1 and when I pre-oiled it yesterday it gushed oil in to the top of the heads instantly, not sure if the rest of the motor got oiled. I've never ran Indys before where they were oiled with the oil lines from the back of the block. They are just #4 lines and fittings and I'm thinking I may need to restrict the amount of oil being pushed up to the top of the motor so I wanted to see if others are restricting the oil on their -1s and how they are doing it.
I was thinking that I could drill and tap the fitting that screws into the heads and put in a carb jet or some other type of jet.
So is it necessary and how did you restrict oil?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Restricting oil to rockers on -1s, necessary? how? [Re: WadeMetzinger] #182318
01/03/09 10:37 AM
01/03/09 10:37 AM
Yes, it's necessary and that's a good way to do it.
Re: Restricting oil to rockers on -1s, necessary? how? #182319
01/03/09 10:56 AM
01/03/09 10:56 AM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
I have one that uses a nitrous jet. No tapping is involved just drilling. The flare on the nitrous fitting seals against the AN fitting. I have another that the fitting is drilled an tapped and I put a set screw in with a .062 hole drilled in it.
Jack
Re: Restricting oil to rockers on -1s, necessary? how? [Re: WadeMetzinger] #182320
01/03/09 11:04 AM
01/03/09 11:04 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Re: Restricting oil to rockers on -1s, necessary? how? [Re: camdog440] #182321
01/04/09 10:24 PM
01/04/09 10:24 PM
Tulsa, Ok
Tulsa, Ok
Thanks for the replies and the link. I drilled and tapped the fitting with a #74 holley jet and it worked just fine!
Re: Restricting oil to rockers on -1s, necessary? how? [Re: WadeMetzinger] #182322
01/05/09 12:10 AM
01/05/09 12:10 AM
fullmetaljacket Offline
Is this over-oiling just found with 1s or is it also with the rest of Indy heads, ie: Sr's
Re: Restricting oil to rockers on -1s, necessary? how? [Re: fullmetaljacket] #182323
01/05/09 12:16 AM
01/05/09 12:16 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
SR,s and 440-1s
1.39 9.85 - 137 mph
Re: Restricting oil to rockers on -1s, necessary? how? [Re: Ari440] #182324
01/05/09 12:33 AM
01/05/09 12:33 AM
Well I'll be D'd!
What up Ari?
Re: Restricting oil to rockers on -1s, necessary? how? [Re: fullmetaljacket] #182325
01/05/09 12:36 AM
01/05/09 12:36 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Well I'll be D'd!
What up Ari?
good , you ?
new toy : 1972 roadrunner
1.39 9.85 - 137 mph
Re: Restricting oil to rockers on -1s, necessary? how? [Re: Ari440] #182326
01/05/09 01:34 AM
01/05/09 01:34 AM
Crazed and dazed. Motor down and out with a headache and heartburn, ie: heads with sealing problems and rings gone south.
It's in good hands now.
Hope to see ya at the haunts this season.
Best.
