1 7/8" or 2" headers for my build? #1822458
05/09/15 04:46 AM
05/09/15 04:46 AM
Tacoma, Washington USA
Adam71Charger Offline OP
About to drop in my 440. I think 1 7/8" headers are what I need, but wanted some other opinions. The main reason I am thinking about 2" is because my goal at some point is to put a larger engine in the car, and would like to re-use the headers.
But if 2" will end up losing substantial torque/hp from my current engine, I do not want them.
Here's the quick info on my setup. Street/strip. 71b. 440, ported RPM heads, 10.2:1 compression, duration @.050 intake 244 exh 252, LSA 8 degrees, Gross valve lif intake .520 exh .541, 3500 stall.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1822480
05/09/15 08:48 AM
05/09/15 08:48 AM
Central NC
gch Offline
gch  Offline
Central NC
1 7/8 would be my choice for a street car.
Re: 1 7/8" or 2" headers for my build? [Re: gch] #1822486
05/09/15 09:32 AM
05/09/15 09:32 AM
IN
ahy Offline
ahy  Offline
IN
I run 1 7/8" on my 496/Ed head and am happy with them. I think the 2" would make meaningful difference with higher flow heads & high RPM.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1822635
05/09/15 01:41 PM
05/09/15 01:41 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Considering you may want to go bigger later, I would go with the 2-inch.
I went with with 2 1/8" TTI Step Headers. They recommend them for up to 600 HP. Here is a link:
http://www.ttiexhaust.com/Category-ClassicHeaders/Subcategory/ccBigBlock-RB.htm
You might also consider looking at or calling various header manufacturers and ask their recommended size and design.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1822657
05/09/15 02:04 PM
05/09/15 02:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
Two inch, especially with a stroker in your future work up twocents
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1822665
05/09/15 02:21 PM
05/09/15 02:21 PM
it is very common for a person to select parts for what they are thinking about in the future rather than what is right in front of them & even so with that I'd still suggest 1&7/8. I have some super stealths in front of me right now & I measured the ports & 1&7/8 is what I will be going with
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1822703
05/09/15 03:03 PM
05/09/15 03:03 PM
AndyF Offline
AndyF  Offline
I run 2 inch dyno headers on 500+ inch engines that make more than 800 hp so I doubt you need them on a mild perf street car.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1823044
05/09/15 11:17 PM
05/09/15 11:17 PM
AndyF Offline
AndyF  Offline
PipeMax will tell you to put 1 3/4 headers on a mild 440. If you look at the size of a big block exhaust port you'll see that a 1.50 inch header pipe will work. I don't thin anyone builds them that small but that is roughly what the size of the port is.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1823518
05/10/15 04:43 PM
05/10/15 04:43 PM
thanks for all the replies. I need some clarification, if 1 7/8 is the right choice for this engine, what exactly do I lose by going 1/8" too big? Is it a loss of tq, hp or both? Is the loss down low, high or across the entire rpm range? If it is a loss, how much are we talking?
Also, a few things I forgot to mention, I will be adding nitrous to this engine. Not alot, probably 200 shot.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1823614
05/10/15 08:01 PM
05/10/15 08:01 PM
Central NC
gch Offline
gch  Offline
Central NC
When I had 2" headers on the 470 in my 4000 lb charger I noticed a drop in part throttle responsiveness.Anything less than full throttle it felt lazier than the 1 7/8.I was also running 4.10 gears.
For a heavy car torque is king.2" will make more peak hp and TQ and maybe at a slightly higher rpm.Unless it is a dedicated track car I will take the torque of the 1 7/8 over the 2" hp.Make sure your exhaust system is free flowing for either.
On a 200 shot I would be looking for a cam ground for nitrous.
Re: 1 7/8" or 2" headers for my build? [Re: gch] #1823642
05/10/15 08:28 PM
05/10/15 08:28 PM
My cam and my compression are why I chose a smaller shot. The engine is already built and the nitrous wont be used very often.
Im getting the TTI headers, and the guy I called there basically just repeated what was on their web page, that 1 7/8 was for 400-600hp, and 2" was for 600 and up.. I wasnt satisfied with the generic description so thats why I posted. Thanks for the explanation!
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1826759
05/14/15 06:28 PM
05/14/15 06:28 PM
M.A.
Fern Offline
Fern  Offline
M.A.
If you go on the TTI website, you will notice that the 1 7/8" headers are layed out differently than the 2".
Depending on what car you are installing them on, one may fit better than the other. I have an e body and the 2" clear the steering linkage fine where as the 1 7/8" are very close.
Re: 1 7/8" or 2" headers for my build? [Re: Adam71Charger] #1826765
05/14/15 06:33 PM
05/14/15 06:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
1-7/8" were good enough for me to go 11.0s w/ a 440 E-body. I only switched to 2" when the car was fast enough to run 10.5s.
You don't have a 2" combination and will be happier staying w/ the smaller headers, unless you make MAJOR changes to your combination.
