Big Block Mopar (1) piece rear main seals #1822541
05/09/15 11:37 AM
05/09/15 11:37 AM
good ole USA
moparlifer Offline OP
good ole USA
Has anyone used these with good luck? Seams as though Performance-seal handles them. I don't know the manufacture which would tell us material?
Re: Big Block Mopar (1) piece rear main seals [Re: moparlifer] #1823025
05/09/15 10:48 PM
05/09/15 10:48 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
I have not heard good things about these. Very difficult to install correctly -- you've got to cut the seal to install it -- so it's really not a one piece deal after doing that to it..........
Re: Big Block Mopar (1) piece rear main seals [Re: moparlifer] #1823560
05/10/15 06:01 PM
05/10/15 06:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What if you have the crank out while you're installing it?
Re: Big Block Mopar (1) piece rear main seals [Re: moparlifer] #1823985
05/11/15 06:35 AM
05/11/15 06:35 AM
DeMopuar Offline
DeMopuar  Offline
You cannot get the seal over the rear crankshaft flange -- the instructions state you need to cut it to install it. You would be installing this when the crank is out no matter what.
Re: Big Block Mopar (1) piece rear main seals [Re: moparlifer] #1824047
05/11/15 11:39 AM
05/11/15 11:39 AM
good ole USA
good ole USA
I found that Pontiac has a one piece seal for their engines 400 and 455. the seal comes marked to show cut location, (between the wire re-inforcement). Users find it easy to install and leak free! This seal must be similar to the one piece mopar, and still looking for the maker?
Re: Big Block Mopar (1) piece rear main seals [Re: moparlifer] #1824336
05/11/15 06:08 PM
05/11/15 06:08 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Even with a cut it still has one less spot to leak. ???
I want my fair share
Re: Big Block Mopar (1) piece rear main seals [Re: DeMopuar] #1824592
05/11/15 10:47 PM
05/11/15 10:47 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
We use one piece crank seals on airplanes, and they work fine. We heat them a little, and take the spring out, and there is a special tool that strechs it over the flange.
