American Grade 8 bolts #182228
01/03/09 02:13 AM
01/03/09 02:13 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
are these "JH" grade 8 bolts chinese? if so I wanted to replace them with some quality USA made pieces.
they are 1/2" bolts 3 inch under head length fine thread. I need four bolts.
Already called ARP and they don't have them in the 5 packs.
was wondering if anyone knew of a source as I dont mind paying for quality bolts
if not I'll just use them
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: American Grade 8 bolts [Re: RylisPro] #182229
01/03/09 02:17 AM
01/03/09 02:17 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
What application?
Unless it's an internal engine fastener there is usually not a problem with cleaning up and re-using the factory Chrysler bolts. I'd trust an oem bolt long before a Home Depot bolt.
Re: American Grade 8 bolts [Re: Neil] #182230
01/03/09 02:18 AM
01/03/09 02:18 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
sorry forgot to mention
its for my motor plate
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: American Grade 8 bolts [Re: RylisPro] #182231
01/03/09 02:20 AM
01/03/09 02:20 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: American Grade 8 bolts [Re: RylisPro] #182232
01/03/09 02:32 AM
01/03/09 02:32 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
ARP sells assorted size bolts as well as thier normal engine ones
Re: American Grade 8 bolts [Re: RylisPro] #182233
01/03/09 02:33 AM
01/03/09 02:33 AM
[are these "JH" grade 8 bolts chinese? I'll just use them thanks
Chinese bolts would not have English letters on them. You're Ok as is.
Re: American Grade 8 bolts [Re: RapidRobert] #182234
01/03/09 10:45 AM
01/03/09 10:45 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If this link:
http://www.digest.net/bmw/archive/v5/msg02623.html
is to be believed, what you have was made in Taiwan. On the flip side, Grade 8 SHOULD be Grade 8 regardless of who sells it but you never know. There was at least one case I was aware of years ago when International Harvester (I told you it was years ago) had bought a batch of cheap bolting, used it in the front ends of trucks, and then started having failures. Real mess IIRC.
Re: American Grade 8 bolts [Re: RylisPro] #182235
01/03/09 10:49 AM
01/03/09 10:49 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
If you want something really hard
go to a CAT dealer.
Re: American Grade 8 bolts [Re: cyphre666] #182236
01/03/09 10:54 AM
01/03/09 10:54 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
home depot is cheap stuff. but, I've not had any problems with the stuff I've bought there. I just hate the gold zinc'd plating they put on them! its so hard to find black oxide bolts!
maybe fastenal has what you need? they have great selection, but too bad in my experience, they make you buy a bag of 50!
**Photobucket sucks**
Re: American Grade 8 bolts [Re: 70Cuda383] #182237
01/03/09 11:53 AM
01/03/09 11:53 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
1/2-20 x 3 Grade 9 Yellow Zinc Hex Cap Screw
http://www.fastenal.com/web/products/detail.ex?sku=20862
I think I found what I was looking for
these bolts are GRADE 9! wow! didn't know those existed
nice price too
thanks
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: American Grade 8 bolts [Re: RylisPro] #182238
01/03/09 01:35 PM
01/03/09 01:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Technically, there is no such thing as a "grade 9" rating, there is a brand label "grade 9' but not a sanctioned rating, even though its strenght may exceed grade 8.
Re: American Grade 8 bolts [Re: jcc] #182239
01/03/09 02:08 PM
01/03/09 02:08 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
you are right, I researched them a bit and they are L9 bolts. L9 bolts have a minimum tensile strength of 180,000 psi, which is significantly higher than the standard for Grade 8
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: American Grade 8 bolts [Re: cyphre666] #182240
01/03/09 02:21 PM
01/03/09 02:21 PM
go to a CAT dealer.
I've used them & they are black in color I'm assuming that is black oxide
Re: American Grade 8 bolts [Re: RapidRobert] #182241
01/03/09 05:30 PM
01/03/09 05:30 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i bought some 5/16's bolts from fastenal the other day,it said made in china right on the plastic bag,i have used cat bolts in the past,they are good stuff!!
i was useing their grade 8 bolts for diesel head bolts,never broke one
Re: American Grade 8 bolts [Re: 6PakBee] #182242
01/03/09 08:36 PM
01/03/09 08:36 PM
Caldwell. Id
E
edbux Offline
edbux  Offline
E
Caldwell. Id
The Air Force got bit several years ago by a supplier. Sent them "grade 8 bolts" which were nothing more than standard bolts that were plated.
I can't remember the exact story, but someone tested
them found them not to the standard. After an investigation, they were found to have been made in China and someone along the way sent false documentation along with them.
The JH is probably the manufacturer.
1967 Dart 270 360/727
Re: American Grade 8 bolts [Re: RylisPro] #182243
01/05/09 04:23 PM
01/05/09 04:23 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I found a CAT dealer nearby and got some bolts
gonna replace all my bolts with either CAT or ARP
the CAT deal was pretty cool
turns out they got a bunch of USA made tools and stuff
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: American Grade 8 bolts [Re: RylisPro] #182244
01/05/09 04:29 PM
01/05/09 04:29 PM
United States
STLDuster Offline
STLDuster  Offline
United States
So you just go in to a Cat dealership and ask for them, how does that work? I have never been to one before.
Neat Idea!
"No great genius has ever existed without some touch of madness." - Aristotle
Re: American Grade 8 bolts [Re: STLDuster] #182245
01/05/09 04:33 PM
01/05/09 04:33 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Yup, just found the closest one on their website and asked for bolts. They were hella cheap too $1.59 per bolt. they even gave me a part and tools catalog
http://www.cat.com/cda/layout?m=37648&x=7
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: American Grade 8 bolts [Re: RylisPro] #182246
01/05/09 05:21 PM
01/05/09 05:21 PM
United States
STLDuster Offline
STLDuster  Offline
United States
It would appear that JH fasteners are Chinese. Correct me if I am wrong because I have used a bunch of these from the local hardware store.
http://www.jhfastener.com/Elxwm.asp
Re: American Grade 8 bolts [Re: RylisPro] #182247
01/05/09 06:00 PM
01/05/09 06:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
"Grade 8" is a spec so it's unlikely that it matters where they're made, the spec will be the same i.e. you can't stamp "grade 8" on a plastic bolt !!!
As for that cheap bolt story, they bought exactly that ... cheap bolts, not a specific grade that wasn't up to spec.
Grade 8 in your application is probably overkill and a waste of money. Before spending money on good bolts you should research the strengths of the various bolts and determine your needs. In this application a grade 2 bolt will probably do just fine! Don't like that, then step up to a grade 5. Grade 8 ???? Unnecessary.
