Re: 426 Hemi Intake Gaskets - How Do You Seal Yours?
[Re: ScottSmith_Harms]
#1822188
05/08/15 09:59 PM
05/08/15 09:59 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I torqued mine about 10 times before it held the proper torque because the intake kept settling. I followed the pattern each time also. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1822294
05/08/15 11:20 PM
05/08/15 11:20 PM
Posts: 12,953 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
I agree, several re-torques over several days. Until the torque repeats over a couple of days.
I also like the gray YamaBond or Honda stuff around the ports for a little extra insurance.
And then there's the pink gaskets from Superformance.
Master, again and still
#1822460
05/09/15 05:23 AM
05/09/15 05:23 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
Just installed SUPERPERFORMANCE intake gaskets,hemi port was on the money.I need to retorque the intake bolts.
#1822537
05/09/15 11:27 AM
05/09/15 11:27 AM
DaveRS23
Benton, IL.
If I have a problem child, I Yamabond both sides. If there is no history of sealing issues, then YamaBond the head side and grease on the intake side.
I used the Superformance gaskets this last time (my first time with them on this) and they did torque quicker than the others. As to whether they seal better, we'll see.
I wished that it wasn't so expensive to have these things O-ringed. Last time I checked, it was $500 plus shipping. But I just might go ahead and do it on this next engine. If there is no sealing issue, then it is a waste of money. But on a problem child, it would be worth every penny. But you don't know until it's up and running.
[Re: roadhazard]
#1824522
05/11/15 09:30 PM
05/11/15 09:30 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
Thanks for all the positive responses to the Superformance Hemi intake gaskets!
My recommended installation is to adhere one side of the gasket to the cylinder head or intake manifold flange surface with an adhesive, generally away from the ports. Some form of High-Tack, Weatherstrip Adhesive or other. (Sillycone is not recommended around the intake ports..... your mileage may vary.) Allow to dry before installation of the manifold so gasket does not tend to slide upon installaton or torque.
I also think applying a very thin film of White Lithium grease or the like to the opposite sealing surface of the gaskets may have some benefit of allowing the manifold to slide into place easier during the torquing procedure. I relate this to the angle of the bolts/studs relative to the sealing surface and the direction of torque load being applied.
There is NO need to coat the cut edges on any of our premium gaskets..... save that for all the inferior products on the market.
Scott I'm sure we missed the opportunity for you to use our gaskets being as you were installing the manifold this weekend but keep us in mind when it's time R&R that manifold again. Scott, just so you know, there is no more "stand up" guy in the Mopar world than this guy.
[Re: Hemi ragtop]
#2144672
08/31/16 04:47 PM
08/31/16 04:47 PM
Posts: 1,153 Home of the Bluegrass
MoparJunkie
Scott, you have been a help to so many here, hopefully I can help you on this one. My intake sealing problems were of the EXTREME variety! Oil consumption was 1 quart per 100 miles. I removed the intake to find that the gaskets were still sealed (silicone) to both head and intake surfaces, the oil was being sucked THROUGH the gasket! I checked for both straightness and parallel angles, both were right on. This brought me to Superformance gaskets. I first installed them dry. Oil migrated past them on both intake and head surfaces. I then studded the intake, installed new Superformance gaskets, lightly coated both sides with Hondabond and torqued them to 125 inch pounds. Problem solved. If you don't mind may I ask where you bought the studs and nuts from???? TIA
"It takes a Mopar to catch a Mopar” 1970 Challenger T/A 4 speed EV2
