Is this a teflon valve stem seal? #1822089
05/08/15 08:09 PM
05/08/15 08:09 PM
SINY
SanityLost Offline OP
SINY
I think it is just looking for clarification. Does it look like its installed correctly?
Should there also be a umbrella seal over it?
Re: Is this a teflon valve stem seal? [Re: SanityLost] #1822121
05/08/15 08:55 PM
05/08/15 08:55 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
1MYTGTX
Re: Is this a teflon valve stem seal? [Re: SanityLost] #1822139
05/08/15 09:14 PM
05/08/15 09:14 PM
SINY
SINY
OK so if one were to change them out, Heads on or off and is there a puller of some type that removes the teflon type seal?
Re: Is this a teflon valve stem seal? [Re: SanityLost] #1822159
05/08/15 09:37 PM
05/08/15 09:37 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
There's no puller, but there is an installation tool and a thin plastic cap for the valves that prevent galling the new seal
Re: Is this a teflon valve stem seal? [Re: SanityLost] #1822410
05/09/15 01:53 AM
05/09/15 01:53 AM
You might want to replace those with the newer Viton valve seals avaible today scope Teflons use to be the hot ticket years ago, they don't keep the oil out of the combustion chambers like the newer Viton seals do scope shruggy
Re: Is this a teflon valve stem seal? [Re: SanityLost] #1822513
05/09/15 10:48 AM
05/09/15 10:48 AM
SINY
SINY
Being they are the teflon valve seal and the guides are machined for them, Do I need to change the guides now so the Viton type seal will work?
And again, should I take the heads off to change these out? I pretty sure IF I have to change out the guides that YES the head has to come off... mad
