Notching cast slugs
#182185
01/03/09 12:28 AM
01/03/09 12:28 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Has anyone here notched a flat top Silvolite slug - and if so, how deep? A retailer who sells them have told me that they don't "recommend" notching them - but the supplier (United" claim they are of a suitable thickness) So I need some personal experiences....
Re: Notching cast slugs
[Re: Moparmal]
#182187
01/03/09 01:53 AM
01/03/09 01:53 AM
RapidRobert
They can be notched as long as you have at least .150" thickness left. I am going to put a sharpened 1/4" rod in a vise & the support rod for my dial indicator in the vise several inches away & set the dial indicator plunger down on the tip of the sharpened rod, zero it then raise up the plunger & set the piston on the sharpened rod & the plunger down on top of the piston & see how thick the deck is to start with & that's as far as I have gotten with this. I haven't yet found a co that sells a cutter that I can chuck in my drill press & someone welded? several small bars to the bottom face of an old valve & it worked to cut the soft aluminum piston but I dont remember how they did it.
[Re: goldmember]
#182189
01/03/09 02:03 AM
01/03/09 02:03 AM
RapidRobert
Thanks Bro. I will check their site.
[Re: goldmember]
#182191
01/03/09 02:14 AM
01/03/09 02:14 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Isky used to rent the tool,might give them a call.
Your an old fart too...They don't seem to rent it anymore now they sell it...
[Re: goldmember]
#182195
01/03/09 02:37 AM
01/03/09 02:37 AM
RapidRobert
I checked their site & they have cutters for sale but no rentals & for their prices I'm gonna have to figure something out that's cheaper.
[Re: goldmember]
#182197
01/03/09 02:53 AM
01/03/09 02:53 AM
RapidRobert
I think I am going to weld a small bar of tool steel to a valve do it that way I've been dragging my heels on this deal for too long.
[Re: JBurch]
#182200
01/03/09 08:33 PM
01/03/09 08:33 PM
Moparmal
Thanks JBurch - Ive decided to buy one cast slug and get it checked and test cut... Then I'll know which combo I will have to go with - a 318/349 with cast slugs or a 318/390 with forged an a new crank.
