Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182175
01/03/09 02:56 PM
01/03/09 02:56 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
How about a little info on the motor, what weight car it is going in, etc
It is going in a 69 dart with ladder bars, and coilovers. It weighed 3050lbs race ready before with w2s on it. It should be 2975 or so with the w5s or so I am hopeing. I have lost a little weight also . Motor is 408ci, 14-1comp,SDSS max effort w5s with a 683,728 roller. IT has a 727 trans with a 5200 vert. Hopefully it will run.
What Guts are in it?? Crank, Rods, Pistons, and what block you using?
Re: New bullet, W5, 408 injected on alky [Re: Moparnut426] #182176
01/03/09 03:21 PM
01/03/09 03:21 PM
oregon
greendart408 Offline OP
oregon
Mp, scat 4340 4in crank, eagle 6.200 rod, je pistons. Stock block, sonic checked with pro gram billet splayed caps.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182177
01/03/09 04:05 PM
01/03/09 04:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Just so you know, with the 650-680 horse you are throwing at that block, it will split.
Its a definate mistake...sorry gotta say that
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182178
01/03/09 04:49 PM
01/03/09 04:49 PM
Canada
lenweiler Offline
lenweiler  Offline
Canada
Nice. Real nice.
Damn! I dropped my change.............
Re: New bullet, W5, 408 injected on alky [Re: B3422W5] #182179
01/03/09 08:26 PM
01/03/09 08:26 PM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
It sounded like it was a killer combo till the stock block bit.
Don have you broken a stock block before?
Re: New bullet, W5, 408 injected on alky [Re: vc360] #182180
01/03/09 08:41 PM
01/03/09 08:41 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
Killer Small Block
