Page 1 of 3 1 2 3
which is better and cheeper 8 3/4 or 9 inch #1821551
05/08/15 01:16 AM
05/08/15 01:16 AM
Texas
ralph67 Offline OP
ralph67  Offline OP
Texas
help the diff people are trying to get me to switch over to a 9 inch. What are the pros and cons of a 9inch vs 8 3/4
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821574
05/08/15 01:44 AM
05/08/15 01:44 AM
Washington
skrews Offline
skrews  Offline
Washington
Here we go again.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: skrews] #1821577
05/08/15 01:48 AM
05/08/15 01:48 AM
Texas
ralph67 Offline OP
ralph67  Offline OP
Texas
Originally Posted By skrews
Here we go again.
Just enjoy the ride cool
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821593
05/08/15 02:01 AM
05/08/15 02:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its more about the weight of the car and the power you run..
this have been discussed many times over... myself I run a 8 3/4
in one car and a 9" in the other.. the 8 3/4 in the race car BUT
its light.. and the 9" in my street rod.. they all have there place..
if you go with either I would recommend a back brace on them.. load
bolts help the 8 3/4... also a MW cap on the load side helps
wave
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821602
05/08/15 02:07 AM
05/08/15 02:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Long term...... 9" all the way!
Re: which is better and cheeper 8 3/4 or 9 inch [Re: J_BODY] #1821629
05/08/15 03:21 AM
05/08/15 03:21 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
And a lot more options.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: Randy..] #1821634
05/08/15 03:36 AM
05/08/15 03:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
We all know that there is a larger gear selection for the 9"
but lets hear some FACTS on what he has before we get carried
away at spending HIS money.. sounds like he has a 8 3/4 now but
we know nothing..... so to the OP.. what do you have.. fill in
some blanks here
wave
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821641
05/08/15 04:01 AM
05/08/15 04:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have both in my cars, both are good products but the 9" has more options available, more choice of cases, more choice in gears more choice in spools & more choice in lockers. Both the 9" & the 8 3/4 have the same stock case weak link, the bearing caps are weak. if you're going racing i'd go with the 9", if you're just a streeter, then the 8 3/4 will be just fine.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: MR_P_BODY] #1821664
05/08/15 06:31 AM
05/08/15 06:31 AM
Q
Quicktree Offline
Quicktree  Offline
Q
some blanks here
wave
the facts are don't waste your money on an 8-3/4 period
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821693
05/08/15 09:16 AM
05/08/15 09:16 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
9" is a good bit stronger. There are more parts available for it also.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821722
05/08/15 11:23 AM
05/08/15 11:23 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Either one of these can be made better but then it won't be cheaper.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821745
05/08/15 11:58 AM
05/08/15 11:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What car and what is the application? I'm guessing you already have the 8.75? If I was starting a project from scratch and didn't have either, I'd probably go w/ a 9". BUT if I had a running driving car w/ a 8.75 I'd stay with that.
Coming soon!!!!
Re: which is better and cheeper 8 3/4 or 9 inch [Re: rebel] #1821776
05/08/15 12:52 PM
05/08/15 12:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Of course it's the 8 3/4.......
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821800
05/08/15 01:17 PM
05/08/15 01:17 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Oohhhso you come here to start fight.
Finish him.
Seriously though you should give intended use and power weight of car manual or automatic transmission with our without trans brake.. Maybe you need a Dana 60 instead.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821803
05/08/15 01:24 PM
05/08/15 01:24 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
10 bolt chevy's to the front. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: which is better and cheeper 8 3/4 or 9 inch [Re: dezduster] #1821870
05/08/15 02:57 PM
05/08/15 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Finish him.
He hasnt been back to give any info.. I think his plan was
to start some BS.. and he has 5 posts
wave
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821880
05/08/15 03:10 PM
05/08/15 03:10 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
In that case Dana 60, nothing stronger in STOCK form smile
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821888
05/08/15 03:23 PM
05/08/15 03:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If I had to set one up it'd be the 9"....pinion depth changes are a lot easier.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821929
05/08/15 04:53 PM
05/08/15 04:53 PM
Texas
ralph67 Offline OP
ralph67  Offline OP
Texas
no, no BS starter here just looking for opinions on the 2 different rears.
i am in the process of building a Duster with a 511 BB, 727 trans and have a 8 3/4 being narrowed for the rear.
Re: which is better and cheeper 8 3/4 or 9 inch [Re: ralph67] #1821930
05/08/15 04:56 PM
05/08/15 04:56 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
If you are spending the cash to narrow an 8 3/4 I would consider a Dana and be done.
5.53 @ 125 1/8th on the launch control..more left in her!
Page 1 of 3 1 2 3
