Comp valve spring QA #182152
01/03/09 12:18 AM
01/03/09 12:18 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
Ive read that the quality on Comp valve springs is open to question -
Anyone confirm a premature loss of pressure with new Comp double springs?
Re: Comp valve spring QA [Re: Moparmal] #182153
01/03/09 12:49 AM
01/03/09 12:49 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You may want to post that one in the racing section. I haven't used the comp valve springs so I have no first hand experiance. My machinest says he usually installs the valve springs with a bit more pressure (shorter install height) because the springs will loose some seat pressure after the first few runs?
If the cam is fairly mild I don't think it is that big a deal, but with a big solid or roller it could make a difference.
