Rod failure
#1821479
05/08/15 12:16 AM
05/08/15 12:16 AM
Posts: 576 Texas
ChevyTS
Texas
Not really a question I just wanted to share some information. A while ago I built an engine for myself using left over parts from my old mans bracket car. I had a 4.150 stroke RB crank that I had welded and repaired. I had four used eagle h beam rods. I posted an ad in the wanted section and a nice fellow sold me three used rods to match mine. I ordered one new rod from Eagle to complete the set. I also still had a nice set of pre tested (used)JE dome pistons. I toped it off with a set of stage 6 heads that I built right after I bought my flow bench. Long story short the engine in my fathers car cracked so in the interest of time I let him use the engine I had ready. And as it goes this engine worked very well. The 2800 pound Duster ran 5.72's. Almost matching the best time of the B1 engine that it replaced. Lived through one ring and pinion, my fathers great idea to try 5:13 gears, and a transmission failure. Over 200 passes. Well the other night at Red River (now Thunder Road) during a time trial water on the track caused the engine to over rev its last time. The pics are of one of the used rods.
T & K Performance
Re: Rod failure
[Re: ChevyTS]
#1821544
05/08/15 01:09 AM
05/08/15 01:09 AM
Posts: 576 Texas
ChevyTS
Texas
I do think it was cracked and I just didnt catch it.
T & K Performance
Re: Rod failure
[Re: ChevyTS]
#1821927
05/08/15 04:52 PM
05/08/15 04:52 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Oh that's just one side. The other side is no prettier
Re: Rod failure
[Re: Porter67]
#1824102
05/11/15 12:56 PM
05/11/15 12:56 PM
Posts: 576 Texas
ChevyTS
Texas
That blows. Hi high did it go?
Looks like it was very well pre cracked, What else did it hurt? Not sure but he has a 7500 pill in the rev limiter.
T & K Performance
Re: Rod failure
[Re: Al_Alguire]
#1824106
05/11/15 01:05 PM
05/11/15 01:05 PM
Posts: 576 Texas
ChevyTS
Texas
Oh that's just one side. The other side is no prettier Thats not good. I only lost a factory block.
T & K Performance
Re: Rod failure
[Re: ChevyTS]
#1824240
05/11/15 03:54 PM
05/11/15 03:54 PM
Posts: 16,928 NC
440Jim
NC
I also still had a nice set of pre tested (used)JE dome pistons. Just curious, how did the piston pin look on the failed cylinder? Slide out of the piston OK?
Re: Rod failure
[Re: 440Jim]
#1825718
05/13/15 01:28 PM
05/13/15 01:28 PM
Posts: 576 Texas
ChevyTS
Texas
the pin looked fine! why?
T & K Performance
Re: Rod failure
[Re: 440Jim]
#1832912
05/23/15 06:54 PM
05/23/15 06:54 PM
Posts: 576 Texas
ChevyTS
Texas
Well I started on our replacement B1 low deck. I ordered some new Scat HBeam rods to complete the rotating assembly and one of the rods is defective out of the box. .003 over sized on the big end. As in 2.503. Im shocked, and awaiting word from Scat on what to do.
T & K Performance
Re: Rod failure
[Re: Porter67]
#1833313
05/24/15 04:13 PM
05/24/15 04:13 PM
Posts: 576 Texas
ChevyTS
Texas
If they are numbered close id send the whole box back and ask for a new full set, who knows if the same person/shift/batch are ok.
Its your money, you should expect decent parts. Another example of why its best to check things asap after receipt. Im sure they will be cool about it and replace them. But now I have to answer to the old man
T & K Performance
Re: Rod failure
[Re: Alchemi]
#1833358
05/24/15 06:34 PM
05/24/15 06:34 PM
Posts: 576 Texas
ChevyTS
Texas
I'm glad you mentioned the rust. I was intending on sharing something that I found out the hard way about blocks that have been crack repaired. DON'T USE THEM As I stated in my first post this engine was built using parts that really had no value. Perfect place for me to test a repaired block.
T & K Performance
