Re: Single piston calipers - grease the slides or not?
[Re: SALEM1912]
#1821451
05/07/15 11:51 PM
05/07/15 11:51 PM
RapidRobert
You wouldn't be using enough to contaminate the pads. Get some lube that is a dry type, not sure which but it is out there. You are wanting to avoid regular grease attracting debris in that V groove that could end up being worse than no lube.
[Re: DrCharles]
#1821514
05/08/15 12:40 AM
05/08/15 12:40 AM
Posts: 561 USA
B3RE
USA
I use a product called Sil-Glide. It's a silicone based lubricant specifically recommended for brake systems. You can get it from NAPA.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: DrCharles]
#1822471
05/09/15 07:40 AM
05/09/15 07:40 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I use a dab of never-seize, much more heat resistant.
"I think its got a hemi"
[Re: gdonovan]
#1822517
05/09/15 10:58 AM
05/09/15 10:58 AM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I use a dab of never-seize, much more heat resistant. Same here .
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
