Re: Is spark plug reading accurate enough for A/F ratio?
[Re: ragtop]
#1821230
05/07/15 06:46 PM
05/07/15 06:46 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
No, in my opinion plug reading is not good enough nowadays.
First your only getting an "overall" reading, so you have no indication if for instance your "rich" looking plugs are rich at idle, at full throttle, or at cruise rpm.
And, I think reading plugs is a lost art, so it may be difficult to get it dialed in.
I'm saving up to get a wideband 02 sensor and A/F gauge. I think that's the best way to go.
[Re: ragtop]
#1821509
05/08/15 12:37 AM
05/08/15 12:37 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Can any of these meters be used without drilling any holes in my exhaust. I don't mind if it reads (4) cylinders at a time if there is a probe that goes in the exhaust pipe. Also, does anyone rent these meters? Thanks. The Innovate gauges have an available clamp to put the sensor in the end of the tailpipe. Not sure how accurate they are positioned there. I had mine installed on the driver's side at a muffler shop. They charged me a half hour of shop rate to weld it in. I am only seeing the odd number cylinders but I have an old Heathkit gauge to check to see if both sides match. I might someday install a second sensor on the other side if I have trouble. No one around me rents the meters. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: ragtop]
#1821716
05/08/15 10:57 AM
05/08/15 10:57 AM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Spark plug reading is an art and requires experience to get right. It is a good tool at the track, where you are only concerned with WOT mix but even then should be used with the time slip. Of course, then you need to have clean plugs in for the run and shut the engine off after the stripe so as not to dilute the plug's coloring with engine operation other than wide open.
If this is a street car, plug reading has little or no value. A/F ratios are changing constantly while driving so there cannot be any useful coloring on the plugs.
Fuel distribution among cylinders requires monitoring the individual cylinders in order to measure and then requires more expertise than most of us have to adjust.
If you do not want to drill your exhaust and do not plan to leave the monitor in place, have you thought about having a competent dyno shop tune your carbs? Most wide bands will cost at least a couple hundred dollars, plus there are the jets, bleeds and power valves necessary and then let's not forget about the learning curve.
It might be just as cheap and certainly easier to have a good carb shop do it.
two cents
Master, again and still
[Re: ragtop]
#1822470
05/09/15 07:39 AM
05/09/15 07:39 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
1) No. I do look at them for signs of detonation and oil consumption though.
2) They do make clamp on bungs. Drill a hole and clamp on.
3) Location? I have seen them on a header tube right off the port and as far back as an h-pipe, they all worked fine.
4) Narrow band or wide band, either is better than just reading the plugs.
"I think its got a hemi"
[Re: ragtop]
#1823073
05/09/15 11:58 PM
05/09/15 11:58 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Nope.
It was explained to me once that what you are looking at on the plugs, is what the car was running at idle and coasting. I.E. by the time you roll to a stop: your WFO, or cruising state, whatever you are looking for, is gone from the plug.
Basically you would need to run the car at whatever throttle you are trying to get the reading, and then shut the ignition off, hit neutral, slam the brakes on, yank the hood open, and pull a plug.
I believe it, it makes sense, my opinion only.
I use a wideband instead.
Think about it: EFI fuel tables are not connected to the spark plug, they are connected to the exhaust pipe.
Mo' Farts
Moderated by "tbagger".
