93 drivers side weatherstrip #1821058
05/07/15 02:17 PM
05/07/15 02:17 PM
Colleyville
3hundred Offline OP
3hundred  Offline OP
Colleyville
Finally got the wife's driver side PW working! Unfortunately it doesn't work well. The shop says the weatherstrip is old, sorta sticky and causing additional drag on the motor and regulator.
I'm sure the dealer no longer has it, sources and replacement procedures appreciated!
Thanks,
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 93 drivers side weatherstrip [Re: 3hundred] #1821140
05/07/15 04:25 PM
05/07/15 04:25 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
www.rockauto.com is a good source (among others) for weatherstripping. I have bought a lot of parts for my trucks there.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 93 drivers side weatherstrip [Re: Polarapete] #1821168
05/07/15 04:58 PM
05/07/15 04:58 PM
Colleyville
3hundred Offline OP
3hundred  Offline OP
Colleyville
So I went over there and found this stuff
FAIRCHILD Part # KD1002 {#4083831, 4354047} Components: D1001*2, D1002*2
Glass Run Kit; Upper & Division Bar; Front Left
Glass Run Kit; Upper & Division Bar; Front Right
is this what I'm looking for? Sorry to seem naive, never had to look into this before.
Thanks,
Robert
'69 300 Convertible
'16 300 S Hemi
