is it "normal" for a motor rebuilder NOT installing
#182077
01/02/09 10:39 PM
01/02/09 10:39 PM
Posts: 213 fresno
hyefatman
fresno
Re: is it "normal" for a motor rebuilder NOT installing
[Re: hyefatman]
#182078
01/02/09 10:42 PM
01/02/09 10:42 PM
340dart4spd
Parts Problem
Parts Problem
fuel push rod?
its not un common....unless they installed pump...
[Re: hyefatman]
#182079
01/02/09 10:44 PM
01/02/09 10:44 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'd say it goes with the fuel pump installation. almost impossible to get it to stay in there without the fuel pump on. So, if he bolted the fuel pump up for ya, then I'd say he forgot it. but in general, thats an install item.
[Re: StealthWedge67]
#182080
01/02/09 11:32 PM
01/02/09 11:32 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Was it in there when the engine went to the shop?
[Re: NTOLERANCE]
#182081
01/03/09 12:13 AM
01/03/09 12:13 AM
Posts: 213 fresno
hyefatman
fresno
[Re: hyefatman]
#182082
01/03/09 12:23 AM
01/03/09 12:23 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
so many folks run electric pumps these days, that he figured it would be better for you to install it when you bolted your pump on, instead of him installing it, and it getting left in there when you put an electric pump on it.
it's also common for them to leave out the oil slinger on hte timing chain too. I know that I left it off of mine when I put it together. didn't even bother with it, not sure if it would have fit with the new wider chain anyway
**Photobucket sucks**
