727 TF Converter housing question #1820692
05/06/15 11:38 PM
05/06/15 11:38 PM
hickory nc USA
skyhawk61 Offline OP
hickory nc USA
Any of you ever seen a 727 TF with a half-dollar sized hole in the bottom of the converter housing? The hole is in a '63 push button unit from a Chrysler 300 that I installed along with a '68 383 in my 59 Plymouth. It looks like a factory drill job. Purpose?
Re: 727 TF Converter housing question [Re: skyhawk61] #1820922
05/07/15 10:29 AM
05/07/15 10:29 AM
scratchnfotraction Offline
front seal inspection hole?
I have seen holes up top on the bell for vans/MH for a timing light.
can you see the bottom of the seal with a flashlight?
would be easy to find a front pump seal leak.
