backspace on 15x5 wheel? #1819852
05/06/15 12:30 AM
05/06/15 12:30 AM
central new york
pettyblue440 Offline OP
central new york
looking at a set of wheels for the front of my bee and they have 2.5 backspacing. will this work okay? probably a dumb question but I never paid attention to the front backspace before. thanks, jon
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819870
05/06/15 12:43 AM
05/06/15 12:43 AM
IN
ahy Offline
ahy  Offline
IN
Generally MOPAR's seem to like "offset" around zero or slightly out on the front. With a 5" wheel 2.5" backspace would be slightly "out"... should not be a clearance problem as long as tires are reasonable for a 5" wheel and should look OK for a front runner type tire IMO. Test fit first would really help make sure.
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819879
05/06/15 12:53 AM
05/06/15 12:53 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Not sure what you have for brakes but make sure they are compatible with discs if you have them. twocents
...FAFO...
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819886
05/06/15 01:01 AM
05/06/15 01:01 AM
central new york
central new york
I have 11" drums
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819892
05/06/15 01:05 AM
05/06/15 01:05 AM
N
NITROUSN Offline
NITROUSN  Offline
N
2.5 means nothing if we don't know how wide the rim is.
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819896
05/06/15 01:07 AM
05/06/15 01:07 AM
central new york
central new york
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819900
05/06/15 01:12 AM
05/06/15 01:12 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That's a narrow rim. What tire size?
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819903
05/06/15 01:17 AM
05/06/15 01:17 AM
central new york
central new york
I don't have tires yet. Maybe I should order a 15x7 for the front.
Re: backspace on 15x5 wheel? [Re: pettyblue440] #1819918
05/06/15 01:30 AM
05/06/15 01:30 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That's what I would be looking at.
