What size is the fuel line on 6-pack cars?
#1819259
05/05/15 11:59 AM
05/05/15 11:59 AM
Posts: 4,287 Danville, NH
Mopar_Mike
Danville, NH
What size is the fuel line on the distribution blocks Up by the carbs on 6-packs? Thanks.
RS23L7 4-Speed
Re: What size is the fuel line on 6-pack cars?
[Re: 62maxwgn]
#1822373
05/09/15 01:00 AM
05/09/15 01:00 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Find someone that sells Weatherhead fittings. Do you know if they exist? Seems guys who race 6 pack cars would want that at least for the first tee
[Re: beecrazy69]
#1824109
05/11/15 01:11 PM
05/11/15 01:11 PM
ademon
IL, Aurora
I am sure it is overkill, but I ran 3/8th to the "T" from the pump. I ran a 3/8 to 5/16 adapter and then put the "T" in the drill press and opened it up a bit.
For how often I am at WOT for extended periods of time, I think the stock size supply line from pump would be fine for me.
My engine is a stock stroke 440 pushing the 3900# Superbee (with A/C, P/S, A518 automatic with 4:10 8.75")to 12.00 at 114mph to give you an idea what I am working with.
Don Good info, thanks
