How high do you spin your 4.15 or 4.25 RB stroker? #1818452
05/04/15 01:46 PM
05/04/15 01:46 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Sheer (morbid?) curiosity... laugh2
Do you build 'em to go much over 7K on the big end, even if you're shifting them below that RPM?
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818454
05/04/15 01:49 PM
05/04/15 01:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
When we ran the B1 all out we shifted it at 8400. I am trying to finish up my 605 and expect to be shifting it around 8200 or so.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818466
05/04/15 02:01 PM
05/04/15 02:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
My first pump gas stroker motor 512/518 C.I. like to be shifted at or above 7000 to 7300 RPM. That motor made peak HP at 5600 RPM and peak torque at 4500 RPM on the engien dyno shruggy At the track it went fastest shifting at or above 7000 RPM, the converter, gear ratio, tire size and all the other variables do come into play work scope
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818472
05/04/15 02:06 PM
05/04/15 02:06 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
6700
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818477
05/04/15 02:11 PM
05/04/15 02:11 PM
AndyF Offline
AndyF  Offline
My 514 dyno motor makes peak power at 7000 rpm so we shut it off fairly quickly after that. It is a 4.15 stroke with a Callies crank and 7.100 Oliver rods so I'm sure the shortblock could handle more rpm, but it just runs out of air.
It still makes 900+ hp at 7000 but if I had bigger heads on it then we could wind it out a bit more and make even more power.
The valvetrain is most likely good to something well past 7000 rpm. I have Jesel rocker arms, a Jesel belt drive, big valve springs and 1/2 inch pushrods so it would spin higher if I had more airflow.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818498
05/04/15 02:24 PM
05/04/15 02:24 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
572 shifting at 7300 trapping at 7500
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818500
05/04/15 02:25 PM
05/04/15 02:25 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
4.15 stroker here. I usually spin it to around 65 at the traps, but have gone to 7 a couple times between shifts, unintentionally...
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818510
05/04/15 02:37 PM
05/04/15 02:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think ET and HP numbers might play a role here too smile Small bore hp=RPM!!
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: Al_Alguire] #1818522
05/04/15 02:49 PM
05/04/15 02:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was gonna have to spin my B1m/c 514 to 8800-9000 to make
it efficient
wave
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818671
05/04/15 06:14 PM
05/04/15 06:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 572, make the shift at 6900 runs 7100 through the traps.
Doug
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: dvw] #1818714
05/04/15 07:18 PM
05/04/15 07:18 PM
hustlin hoosier Offline
We spin our 632 in 7900 to change gears and out the back 8300. It is 4.600 bore and 4.75 stroke. we are in the process of building a 565 in motor 4.600 bore and 4.25 stroke with our new head. I think we will probably be shifting around 8500 and be around 9000 on the big end.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818841
05/04/15 09:29 PM
05/04/15 09:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What block are you using to get q 4.600 bore? Assume it is the Indy 4.84" BS deal. Wish there were some decent heads for that block, like maybe a 4.84BS Predator head.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1818856
05/04/15 09:49 PM
05/04/15 09:49 PM
gregsdart Offline
gregsdart  Offline
7100 shifts, 7800 in the traps with shorter tires. 4.15 stroke, Manley
H beams, 2432 bob weight.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: gregsdart] #1818918
05/04/15 10:53 PM
05/04/15 10:53 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Shift my 540 at 7200 and trap about 7600. Callie's crank and Compstar rods. Been 9.35@143. Looking for more this year.
Randy
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: dvw] #1819039
05/05/15 12:30 AM
05/05/15 12:30 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
My 496, I shift @ 6800 and cross @ 7200!
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1819046
05/05/15 12:39 AM
05/05/15 12:39 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Gee, I feel like a small block guy with only a 505 stroked pump gas 440. I shift at 68 and cross the line at 67. It will easily go to 74 but I see no need to go that high.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: rowin4] #1819082
05/05/15 01:15 AM
05/05/15 01:15 AM
There are a new set of heads that we have just designed. They will be production by the end of July. True mopar wedge they flow equal or better than the predator head with much better velocity. They will be available thru Best Machine Racing 248 987 6038.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1819285
05/05/15 12:45 PM
05/05/15 12:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So is the block Indy 4.84BS???
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: Al_Alguire] #1819287
05/05/15 12:48 PM
05/05/15 12:48 PM
Yes is 4.84 wide flange Indy block. The only way to go.
Re: How high do you spin your 4.15 or 4.25 RB stroker? [Re: BradH] #1819325
05/05/15 01:58 PM
05/05/15 01:58 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Not to hijack the thread ......
Question re shift points. My combo E.T.s best when I shift into second at around 5200 (near peak torque) If I raise the shift point the car slows a couple of tenths. The engine dyno`d at peak RPM / HP @ 6900 and is a 557" RBRE Hemi . Running 14.5/32/15`s , `Glide , 4.10 Dana , 5400 stall Neil Chance conv.
Anyone?
chryco
Again not trying to hijack the thread
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
