Re: Good balancer or elcheapo.... [Re: steve660] #1795277
04/03/15 12:34 PM
04/03/15 12:34 PM
an8sec70cuda Offline
going either Fluidamper or ATI.
I have one of each...no problems w/ either.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Good balancer or elcheapo.... [Re: an8sec70cuda] #1795278
04/03/15 02:06 PM
04/03/15 02:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
ATI period!!! No way to actually check balance on a Fluidampr also they can solidify and cause some ugly issues.
Re: Good balancer or elcheapo.... [Re: steve660] #1795279
04/03/15 02:13 PM
04/03/15 02:13 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Little more info........The engine builder put this balancer on a 4.75 stroke Callies crank. Dyno'd at 1000hp.
Seem to be reliable at 6-700, seen them slip at 800, 1000? No way I would short the mill on a good balancer.
Re: Good balancer or elcheapo.... [Re: RemCharger] #1795280
04/04/15 12:39 AM
04/04/15 12:39 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
I'll be going ATI. Thanks for all the input. I thought it was a low performance / stock replacement unit. Also going to do a thorough inspection on engine. Cant trust what they have told me. Was told they would send build sheet and cam card with engine, still waiting.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Good balancer or elcheapo.... [Re: steve660] #1801996
04/12/15 10:04 PM
04/12/15 10:04 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
...UPDATE... upon closer inspection looks like something has moved / shifted....Look where the bare metal shows no paint and you'll see it. This was after maybe 20 min on dyno...Also still waiting on build sheet, cam card, among other things promised. Patience is wearing thin.....
Re: Good balancer or elcheapo.... [Re: steve660] #1802001
04/12/15 10:06 PM
04/12/15 10:06 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
1 more picture....Im sure I'll be told this is normal. It's just a giant lock ring, right.
Re: Good balancer or elcheapo.... [Re: steve660] #1817192
05/02/15 05:50 PM
05/02/15 05:50 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
This engine supposedly made 1000 hp, yet only had 150 cyl psi. Don't see how that's possible. Must be a happy dyno. Not sure on the cam specs, they wont send me or didn't keep cam card.
Re: Good balancer or elcheapo.... [Re: steve660] #1817213
05/02/15 06:14 PM
05/02/15 06:14 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Don't know what that is but I would chuck it in the thrash. Kick up the cash & get an ATI period.
Re: Good balancer or elcheapo.... [Re: rickraw] #1817230
05/02/15 06:26 PM
05/02/15 06:26 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
Re: Good balancer or elcheapo.... [Re: steve660] #1817437
05/03/15 12:38 AM
05/03/15 12:38 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Like someone said that is a powerbond and yes we use and sell them quite a bit with very good results. However, it has no business on the front of a 622 with 1000 Hp. ATI period. The powerbond units are great for 400 to 600 HP or so bracket style engines. Sorry for your trouble brother. But don't blame the part in this case.
Re: Good balancer or elcheapo.... [Re: steve660] #1817449
05/03/15 12:50 AM
05/03/15 12:50 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I was at the ICH swap and saw the spec card and dyno sheet on a pump gas 451 MM built. Ported 452's, Purple Stripe 474 cam and 10-1 made 525 horse and 570 tq. I'm thinking way happy dyno.
Re: Good balancer or elcheapo.... [Re: slantzilla] #1818551
05/04/15 03:19 PM
05/04/15 03:19 PM
dogdays Offline
dogdays  Offline
Hey, you could give it to me! I'll even pay postage.
From my point of view, the rubbed off paint marks show that the damper was doing exactly what it was supposed to. As the power stroke pushes the hub ahead, the inertia ring stays behind, tethered by the rubber that's between the two. Then the rubber unstretches and the inertia ring is back to the starting point, when another power stroke happens and the same things occur again.
The rubbed off paint shows you how much the inertia ring actually moves. I'm surprised at how much it is, but I've never had a damper on a 1000? hp engine either.
R.
Re: Good balancer or elcheapo.... [Re: dogdays] #1818634
05/04/15 05:11 PM
05/04/15 05:11 PM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
R.
I don't think it's suppose to move ,but I could be wrong.
Re: Good balancer or elcheapo....UPDATE....MUSCLE MOTORS.. [Re: steve660] #1818647
05/04/15 05:33 PM
05/04/15 05:33 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Please note: the SEMA damper standard (S.F.I. 18-1) does not rate a damper’s effectiveness, or certify that it works at all (let alone on a specific motor) - only that it didn’t explode during the test. Their interest is limited to safety and qualify control, not specific engineering results.
Boffin Emeritus
Re: Good balancer or elcheapo....UPDATE....MUSCLE MOTORS.. [Re: steve660] #1818751
05/04/15 07:55 PM
05/04/15 07:55 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I put a Powerbond dampener on my 540 but wish I had used an ATI. The reason is the PB is thinner and the pulleys needed spacers to match what I had on the previous install with a different motor that had an ATI. It also interfered with the cast Indy front cover but I may have the wrong version of that and it was fixed easily enough with a milling machine.
The PB has that huge snap ring in front which I think makes them easier to rebuild. But sending the other dampener to ATI with $75 also gets that done. We'll see how it does as the 540 is very close to first fire after severely hammering on the Proparts (TTI) 2 1/8 step headers to get them to fit in the car.
Re: Good balancer or elcheapo....UPDATE....MUSCLE MOTORS.. [Re: steve660] #1818892
05/04/15 10:23 PM
05/04/15 10:23 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Some damper designs are more tolerant of internal engine mods, in which changes to stroke are probably safer.
If you're not sure, read up.
The "harmonic orders" that cause the problems are not a function of balance, or power, or reciprocating weight. They are far more closely related to:
1. crankshaft length
2. stroke length
3. main journal size
4. rod journal size
5. number of mains
Increases to 1. & 2. reduce overall crankshaft stiffness and reduce the RPM at which harmful orders occur (from which the engine needs protection). Increases to 3., 4., & 5. increase stiffness and increase the critical RPM.
Bottom line: don't use a damper designed for an engine with different crank geometry unless you're sure its design accepts the differences.
A stock 383 has very different crank stiffness from a 4.15" stroker with BBC rods.
Boffin Emeritus
Re: Good balancer or elcheapo....UPDATE....MUSCLE MOTORS.. [Re: polyspheric] #1818909
05/04/15 10:34 PM
05/04/15 10:34 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Is there a mathematical formula to calculate the harmonic orders and a what RPM the may become prevalent? From what you said, a common BB stroker crank with a 4.25 stroke and 2.2 Chevy pins would significantly change the RPM that the harmonics would occur.
Re: Good balancer or elcheapo....UPDATE....MUSCLE MOTORS.. [Re: polyspheric] #1819009
05/05/15 12:10 AM
05/05/15 12:10 AM
Lowes
steve660 Offline OP
steve660  Offline OP
Lowes
2. stroke length
4. rod journal size
5. number of mains
Bottom line: Don't cheap out on a balancer.
Re: Good balancer or elcheapo....UPDATE....MUSCLE MOTORS.. [Re: steve660] #1819199
05/05/15 10:12 AM
05/05/15 10:12 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
In the MP book, in the racing BB section. They talk about dampers. They say to go with a heavy damper. I like the Pro Race brand.
http://www.pro-race.com/prorace.htm
They are SFI approved. I've always had good luck with them. twocents
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
