Re: high idle low vac ?
[Re: scratchnfotraction]
#1818737
05/04/15 07:45 PM
05/04/15 07:45 PM
RapidRobert
if you have over 1 in hg at WOT you would likely benefit from a bigger carb as far as WOT performance goes. 650 is pretty small. I would not be comfortable with 1100 RPM. not sure if its a possible vac leak or carb issue or?? but here's a BTT for ya
#1818759
05/04/15 08:01 PM
05/04/15 08:01 PM
Posts: 3,908 Oregon
hooziewhatsit
What's your initial timing at?
Is your idle throttle open enough to be in the transfer slots?
If I had to guess, I'd say that more initial timing will let you close the throttle more without killing it.
Be sure to keep your total timing in check too.
[Re: hooziewhatsit]
#1818783
05/04/15 08:19 PM
05/04/15 08:19 PM
RapidRobert
Be sure to keep your total timing in check too. X2 X2!
#1818875
05/04/15 10:02 PM
05/04/15 10:02 PM
Posts: 735 Pa. U.S.A.
moparborn
Pa. U.S.A.
I believe a bigger carb will help. What is your vacuum at during wot?,medium+ acceleration? power valve to low maybe. I agree with a good check on timing.
[Re: ahy]
#1819045
05/05/15 12:37 AM
05/05/15 12:37 AM
Posts: 15,487 Florida
scratchnfotraction
I am very close to being in the sweet spot now. I think?
I had help in driver seat while I watched vac gauge under hood.
with the timing light and the damper mark anywhere in the timing scale/tab it seems to retard and ran poorly.
advancing the dist getting highest vac reading of 12"- 13" in N 1000 rpm idle.
vac drops below 4"-3" going into gear then recovers with a stumble and idles or does not recover and dies. a slight tap of throttle as it drops into gear will keep it running. very slight throttle with slight throttle pressure would help idle with it acting like PV bouncing/loading up.
so dropped from 4.5 PV to 2.5 PV with fresh plugs. this cleaned it up a lot on the idle and dropping into gear.
with it advanced for highest vac reading in N it seemd a little to much advance at cruz and had a little kickback on starter when fully warmed.
so I did the hot rod trick of advancing for highest vac reading backing it down 1 full inch on the gauge. this worked ok and seemed closest it has been.
then I advanced the dist to get the highest reading while hot idle in gear = 6" of vac droping down 3.0 - 3.5 going into gear then recover and idle.
now it drive great with a very choppy 850 rpm idle in gear - 1000 rpm in N - drops in gear with out a stumble 90% of the time when full warmed up to temp.
I think it is me having to get used to the lumpy idle and holding the manual brakes and a 1000 rpm idle when in park.
I may still need to recurve a dist or do more fine tunning but right now it seems to be real close on the sweet spot.
idles like a funny car, scares everybody at the gas pumps, idles thru town like a funny car at 25 mph in 3rd @ 1000 rpm idle, chops a load of wood at a redlight, jumps off the line and hits cruzing speeds no effort, kickdown from 55 to 120 with ease even with 2.76 gears 29x15x15 M/Ts.
pretty much everything Hughes said. I just was not expecting it to be this much for a 165$ cam
I am working on the cash for a firecore dist/wire set up hopfully very soon. sparkys PM box is still full.
#1819065
05/05/15 12:57 AM
05/05/15 12:57 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You have to run thru idle mixture, idle speed and timing adjustments a couple of times to fine tune everything properly. One change affects other adjustments.
