Drum Shoe Operation #1817869
05/03/15 06:57 PM
05/03/15 06:57 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
On drum brakes, if the drum is off and the brake pedal is lightly depressed, should both shoes move equally away from the wheel cylinder, or does the leading shoe just move? I know the rotational movement of the drum, if the car actually was moving, will transfer some braking energy to the secondary shoe.
Re: Drum Shoe Operation [Re: davenc] #1817873
05/03/15 07:00 PM
05/03/15 07:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on which return spring is the strongest, the side with the weakest spring will be first to move when the pedal is depressed.
Re: Drum Shoe Operation [Re: davenc] #1817877
05/03/15 07:05 PM
05/03/15 07:05 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Thanks! On both of my rear drums the leading shoe is moving, and I just wanted to make sure there was not a wheel cylinder issue.
Re: Drum Shoe Operation [Re: davenc] #1817891
05/03/15 07:24 PM
05/03/15 07:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
With self adjusters the side with the cable also has more resistance.
