What are these on my mini starter?
#1817857
05/03/15 06:29 PM
05/03/15 06:29 PM
BigAg
I am looking at connection on the cables to my mancini mini starter. Studying the starter I am surprised that i don't recognize everything. 1.In the first picture that should be the Bat Terminal. [img:center] [/img] 2,In the second there is a black plug. Is this the solenoid terminal? I have never seen a plug like this on a starter? What type of connector is this for and is it expected to take it off and use the bolt? [img:center] [/img] 3. What is the brown tube? It looks like a drain tube but i can't imagine what that would be for. [img:center] [/img]
Re: What are these on my mini starter?
[Re: BigAg]
#1818118
05/03/15 11:49 PM
05/03/15 11:49 PM
BigAg
So the plug is for the solenoid and the bolt next to it is for the battery?
I am looking around online for where i could convert my solenoid cable to the male plug but so far no luck.
[Re: BigAg]
#1818220
05/04/15 01:57 AM
05/04/15 01:57 AM
Posts: 43,283 Bend,OR USA
Cab_Burge
Take the starter off and take it to a radio Shack or some other electric supply store and buy the end that fits onto the male connector for the solenoid, be careful on bolting down the main + battery lead onto the stud on the starter, don't let it get close enough to the block to arc or vibrate and touch the block Don't hook the battery up until your absolutely sure everything clears and will work properly Good luck, let us know how you do on this
[Re: Cudajon]
#1819528
05/05/15 06:37 PM
05/05/15 06:37 PM
dogdays
Lots of places sell pigtails. NAPA for one, I think Rockauto does as well. But, they don't list this one. It's a weird plug. I found several pictures online but they must have been the wrong pigtail. The part number is listed in several places as the correct one for the later Mopar starter. The plug was also used on Grand Cherokees, even the 4.0s, according to my research. It's even available with a US Government NSN, and several Russian vendors will sell it to you as well. This is one of the lowest US sellers: http://www.driveoemautoparts.com/oe-mopar/5014098ADMy previous edition of this post was in error. R.
[Re: BigAg]
#1819537
05/05/15 06:57 PM
05/05/15 06:57 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Nearly any electrical plug for anything can be found here: http://www.mouser.com/
[Re: dogdays]
#1820104
05/06/15 11:39 AM
05/06/15 11:39 AM
Posts: 672 NY
twodoorpost
NY
The part number 5014098AD is correct. Here's pics of one in a sealed package and after removal.
[Re: thehemikid]
#1820159
05/06/15 12:35 PM
05/06/15 12:35 PM
Posts: 4,462 Morristown Tn.
71birdJ68
Morristown Tn.
Why not remove the black connector and just bolt the battery & solenoid cables right up to it? The heavier current bolt is exposed anyway(in your pic), even with the black connector in place. Nice touch on safety wiring those screws, but the safety wire is backwards. Ha
[Re: twodoorpost]
#1820207
05/06/15 01:21 PM
05/06/15 01:21 PM
dogdays
Well, you're right. Dozens of places list it as a companion piece to the later starter. Pictures I found must be wrong, although that never happens on the Internet, right? This ought to do it: http://www.driveoemautoparts.com/oe-mopar/5014098ADR.
[Re: 71birdJ68]
#1820339
05/06/15 05:02 PM
05/06/15 05:02 PM
Posts: 1,805 ky hills
thehemikid
ky hills
Why not remove the black connector and just bolt the battery & solenoid cables right up to it? The heavier current bolt is exposed anyway(in your pic), even with the black connector in place. Nice touch on safety wiring those screws, but the safety wire is backwards. Ha Not my work. Plugs & wiring were there when I purchased the block. Saw no real need to change the one for it's sleight error of maybe a 1/8 turn if it loosened. Do any of the black plastic connectors have a protective boot that covers the battery bolt & nut?
