The B body may be totally different from the A body however it's the same tach. You'll need the wiring harness for the tach. You can get that through Classic Industries and some of the Mopar vendors. The harness shown is for 69 so not sure what the differance will be.
If it's like my 68 GTS there will be a hole in the firewall with a grommet inserted. That should have a gray wire that goes to the coil.
Sorry, I miss read your thread. I was thinking 67 GTX
