Re: shocks, shocks, shocks 07 1500 4d 2wd
[Re: modelmakerinc]
#1817385
05/02/15 11:26 PM
05/02/15 11:26 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Monroe reflex, can you tell me why you suggest those?
Nitrousn. It is a two wheel drive truck, the 4wf get a spacer on top of the strut assembly on a 2wd it is a spacer on the coil in the frame pocket I missed the 2wd part. Either way the shock should remain stock and the leveling kit will have an extension for the shock.
