Re: `71 Charger replacement wiper blades hit hood
[Re: 67R/T4speeder]
#1816596
05/01/15 07:32 PM
05/01/15 07:32 PM
Posts: 4,454 Morristown Tn.
71birdJ68
Morristown Tn.
Those aren't the right ones either. You need the ones that were made for the car from back then. Look on ebay. Are the arms all of the way down on the post?
[Re: 67R/T4speeder]
#1816633
05/01/15 08:14 PM
05/01/15 08:14 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I had the same problem with the Imperial. Grab the original wiper and go play match up at the stores. In my case, the solution was some sort of RV wiper blade at Car Quest.
[Re: 71 Charger R/T]
#1821034
05/07/15 01:47 PM
05/07/15 01:47 PM
Posts: 921 Long Island, NY
shocktrp
Long Island, NY
Looks like your post locks are still out…….. That won't allow the arms to pull against the windshield. That's what it was - so that problem is solved. Now that they are working correctly the blades don't clear the hood so I'll be getting a new set like other have suggested.
[Re: mopars4ever]
#1821038
05/07/15 01:54 PM
05/07/15 01:54 PM
shocktrp
Long Island, NY
how long are those blades? i may have a pair like those in the last picture. 16"
[Re: 67R/T4speeder]
#1836811
05/29/15 06:00 PM
05/29/15 06:00 PM
Posts: 553 DE
Ply72rr
DE
