Re: 340 distributor o-ring seal
[Re: markfh52]
#1787165
03/24/15 03:48 AM
03/24/15 03:48 AM
RapidRobert
Call O'reillys & others & you want an 1/8" O ring with an ID ~1&7/8"
[Re: markfh52]
#1787171
03/24/15 01:40 PM
03/24/15 01:40 PM
RapidRobert
If you are in a rush you can use a flat gasket under the base (Ma did it both ways/switched at some point in time/not sure why/likely money/ convenience). You want one thin as a C hair as to not raise the dist/increase the tang slop in the tang/intergear interface. twisting the rotor back & forth slightly just not enough to get into the springs will tell you where you are at with that (with the O ring even). A 4 deg arc of play means the timing can vary 8 deg at the crank (spark scatter). Jerry will take care of ya & here's Jerrys spacers (3/16") installed and you can see that a thin gasket under the wide dist base will seal it up excellent
[Re: markfh52]
#1816094
05/01/15 04:32 AM
05/01/15 04:32 AM
RapidRobert
the metal gasket definitely looks OE. I measured the housing groove at .113" for the top to bottom height and ~.078" for the depth and 2" for the housing OD so I'd say a 1/8" dia O ring with slightly more than 2" OD. EDIT you want it to stretch a bit so maybe slightly less than 2" OD setting loose on your table
[Re: markfh52]
#1816213
05/01/15 11:37 AM
05/01/15 11:37 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Okay, family and business things taken care of and now I can get back to the dart so riddle me this. I got the o-ring from Jerry, thanks. I also ordered one from Bill to get the combo for the distributor.
Both o-rings are not the same as the one I have. They are both larger in ID and don't fit snugly on the distributor and they are both smaller in their thickness.
Kinda of confused at this point.
Your original was round at one time,the current shape is from it conforming to the slot and becoming hard over time.The one Bill R sent is correct.
[Re: markfh52]
#1816728
05/01/15 10:43 PM
05/01/15 10:43 PM
RapidRobert
For sure that 3/32" one ain't gonna work/its the wrong one. someone locally (for you) oughta have one that would fit.
