Page 3 of 4 1 2 3 4
Re: Torsion bar size: How big is TOO big? [Re: 67autocross] #1805696
04/17/15 04:28 PM
04/17/15 04:28 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Originally Posted By 67autocross
Originally Posted By Frankenduster
Seeing the extremely reasonable prices of the BAC torsion bars, I've decided to order a set of the 1.15s and some Bilstien shocks.
I'm about to put some 1.14 bars in one of my A body cars and have started looking into shocks, do you think the Bilstien shocks have enough rebound damping for bars that large?
I have considered the Viking double adjustable shocks but have not heard any feed back on these.
I have had good luck with Bilsteins in general, but on mine I run a specially valved one that feels great with a 300lb bar. I had to make special bushings to adapt it for this application but it was worthwhile.
Re: Torsion bar size: How big is TOO big? [Re: BergmanAutoCraft] #1805710
04/17/15 04:51 PM
04/17/15 04:51 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I have Bilstien's on my Chevy truck and they do work great, but I'm not sure that the off the shelf ones would work with 1.14 bars in a A body. Sounds like you modified yours to work, I want to get something that I can adjust externally for the car and just bolt on.
A new iron curtain drawn across the 49th parallel
Re: Torsion bar size: How big is TOO big? [Re: 67autocross] #1806713
04/19/15 04:30 AM
04/19/15 04:30 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
The 2015 Challenger R/T the wife and I have has Bilsteins as part of the Super Track Pack. I LOVE how the car feels with them.
Re: Torsion bar size: How big is TOO big? [Re: 67autocross] #1806717
04/19/15 04:59 AM
04/19/15 04:59 AM
Victoria B. C Canada
gold66cuda Online content
gold66cuda  Online Content
I have the 1.14 bars in an a body and ran the Bilsteins and they were ok, then I installed the Hotchkis/Fox adjustable and they were a lot better, they take the harshness out of the heavily spring in a light car, much smoother. Having said that I would say if you go with the Bilsteins you will not be disappointed they are a decent shock for sure.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1807144
04/19/15 07:27 PM
04/19/15 07:27 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Yea I think i'm going to go with the Fox shocks, plus if I need to I could always rip apart the Fox shocks and tweak them.
I won't be getting the car out this week...looks like we might get snow in the next few days.
Re: Torsion bar size: How big is TOO big? [Re: 67autocross] #1807225
04/19/15 09:07 PM
04/19/15 09:07 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
In 2005 I added an 1 1/8" front and 7/8" rear anti sway bar set from Addco. Body roll was greatly diminished, but since then the car has always had some oversteer as I pushed it. It would also do something sorta hard to describe: In faster turns whether under throttle, brake or coasting, the rear would feel as if it were ready to step out, come back and then step out again. This is with zero additional steering input. I am wondering if this were a matter of the small torsion bars reacting to irregular road surfaces; the outside wheel/suspension bottoming against the bumpstops then bouncing up off of them.
With bigger 1.15 bars and Bilstein shocks on the way, I hope to report an improvement.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1807345
04/19/15 11:42 PM
04/19/15 11:42 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Are you running biased leaf springs still? I had a problem similar to yours with a rear sway bar until I switched to same rate/arch springs on each side.
Re: Torsion bar size: How big is TOO big? [Re: ntstlgl1970] #1807409
04/20/15 01:18 AM
04/20/15 01:18 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The leafs are the Mopar Performance XHD. They did have an extra 1/2 leaf on the one spring pack but I removed it when I installed the springs.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1807876
04/20/15 05:01 PM
04/20/15 05:01 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
The Viking dbl-adjust shocks are probably the best bet... fully adjustable... lower cost that the QA1 of same/similar design. In fact, the Vikings are made by the original pre-owners of QA1.. there was a recent split in personnell and the President of QA1 founded Viking. Viking only makes dbl-adj shocks and thereby keeops the cost down. Viking also has some slight different design thsatis patented, per my discuissikn with the curent Pres of Viking at a recent trade show.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1808548
04/21/15 12:35 PM
04/21/15 12:35 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I think you make a good point, the Vikings are double adjustable which could really help tune the front of the car. The other advantage I see is I could change torsion bar sizes and keep the same shock, I’m going to start with 1.14s on this car but if they are too stiff I’ll drop to 1.06s. What was the price point on them?
Re: Torsion bar size: How big is TOO big? [Re: 67autocross] #1808556
04/21/15 12:44 PM
04/21/15 12:44 PM
Mopar Mitch Offline
Mopar Mitch  Offline
I think the Vikings dbl adj are ~$160 US each.
Don't be afraid of the 1.14 tbs for your BCuda... John Sandberg runs them on his original owner 67 BCuda fb and they are great for the stret, and improves handling overall. stiffer leafs, an better shocks are needed to help balance the package.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1808588
04/21/15 01:26 PM
04/21/15 01:26 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I'm not to worried about the spring rate, the car is a 68 Plymouth Valiant with a all iron 340, other than the intake. I want this car to be a good all round driver not a full blown race car.
The biggest problem I'm having is what to do with wheels and tires, I would really love to stick to 15" steel wheels and some 225/50 and 275/50 tires but I can't find anything that would work in those sizes.
If I do have to move up to lager rims I will most likely go to the 18" FR500s that Bergman sells with 255 tires on all 4 corners.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1808698
04/21/15 04:14 PM
04/21/15 04:14 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Keep the front and rears the same size for improved handling, that has been recommended by a lot of people on here for most cars including street cars. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1815111
04/30/15 01:57 AM
04/30/15 01:57 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I guess I had to personally experience this to know for sure.
I just finished the installation of a pair of 1.15 T bars from Bergman Auto Craft along with a set of Bilstein RCD shocks. The ride is great, NOT at all harsh. Guys like Mopar Mitch and several others wrote that big T bars are fine for the street and I now see their point. I always went by the guidelines I read in the Mopar Chassis books that listed .96 bars for [/b]Improved street handling[b], 1.0 bars for [/b]Street/Autocross/Road course[b] and anything bigger being for dedicated track cars.
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1815325
04/30/15 12:30 PM
04/30/15 12:30 PM
Mopar Mitch Offline
Mopar Mitch  Offline
You've made good choices.. Enjoy the ride!
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1815416
04/30/15 02:11 PM
04/30/15 02:11 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""I just finished the installation of a pair of 1.15 T bars from Bergman Auto Craft along with a set of Bilstein RCD shocks. The ride is great, NOT at all harsh.""
Can you tell us what size tires you are using all around and what car is this on?
Thanks for your feedback!
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1815440
04/30/15 02:38 PM
04/30/15 02:38 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
1.18's will be in the Dart by the end of next week.
Mopar to the bone!!!
Re: Torsion bar size: How big is TOO big? [Re: YO7_A66] #1815836
04/30/15 09:52 PM
04/30/15 09:52 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The car is a 1970 Charger. 440/493, 727 and an 8 3/4 axle. 4 wheel disc brakes, welded in frame connectors and torque boxes, welded K member with gussets at steering box mounts. Firm Feel Stage 3 steering chuck with Fast Ratio Idler and Pitman.
As far as wheels and tires, I run a staggered size to fit the biggest tires in the car that I could without interference.
Fronts are 18x9 wheels 4.75 BS. 275/40/18 Nitto 555. Rear are 18x10s with 4.75 BS on a 66 B body axle (Narrower than a 68-70 housing by 3/8" per side) Rear tires are 295/45/18 Nitto 555.
The tires are 12 years old and should be replaced. I will go with a 200 TW tire next time since I'd rather wear them out rather than replace them due to age!
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1815930
04/30/15 11:43 PM
04/30/15 11:43 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
Bad to the bone Charger!
1971 6.1 Gen III Hemi Duster
Re: Torsion bar size: How big is TOO big? [Re: Kern Dog] #1815939
04/30/15 11:52 PM
04/30/15 11:52 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Not at all harsh with 1.15" torsion bars and 40/45 series tires is mind boggling to me. It makes me wonder what my sb challenger would feel like with the same 1.15" bars and Hotchkis/Fox shocks with 60 series tires!
Thanks for the update!!
Page 3 of 4 1 2 3 4
