Can anyone ID a Space Saver tire by its decal? #1815122
04/30/15 02:12 AM
04/30/15 02:12 AM
North America
2002bluert Offline OP
North America
I found a space saver tire for sale but not sure what it is out of here is a picture of the decal thats on it.
Re: Can anyone ID a Space Saver tire by its decal? [Re: 2002bluert] #1815154
04/30/15 03:16 AM
04/30/15 03:16 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
How about a picture of the tire on the side were the size of the tire is.
1971 HEMI E BODY REGISTRY
Re: Can anyone ID a Space Saver tire by its decal? [Re: hemicar1971] #1815171
04/30/15 04:23 AM
04/30/15 04:23 AM
North America
North America
This?
Re: Can anyone ID a Space Saver tire by its decal? [Re: 2002bluert] #1815268
04/30/15 11:15 AM
04/30/15 11:15 AM
Ontario, Canada
mccannix Online content
mccannix  Online Content
Ontario, Canada
Thats the common type decal used on E spacesavers and it is an F-78-14 but more info is needed.
Is it stamped K2 over 9 or K2 over 0 in the center lugnut area and to the extreme left of the valve stem and followed by a month date.
Is there a 5.5 to the far right of the valve stem after a number representing the day date
Re: Can anyone ID a Space Saver tire by its decal? [Re: mccannix] #1815288
04/30/15 11:38 AM
04/30/15 11:38 AM
North America
North America
It K2 over a 9 with a dab of white paint over top but cant see any numbers by the valve stem
Re: Can anyone ID a Space Saver tire by its decal? [Re: mccannix] #1815296
04/30/15 11:49 AM
04/30/15 11:49 AM
Ontario, Canada
Ontario, Canada
The other numbers should be there, just covered in paint.
I see a V-1 there in your last picture and if it has and should have TREAD: 3 PLIES RAYON above SIDEWALL: 2 PLIES RAYON.
it's the real deal...you should scoop that spacesaver up fast.
If it is unused and tread is even and perfect you've got a Big $$$ item there.
Re: Can anyone ID a Space Saver tire by its decal? [Re: mccannix] #1815452
04/30/15 03:02 PM
04/30/15 03:02 PM
North America
North America
What's it worth ball park ? And does anyone make a replacement decal ?
