Re: Cragar S/S wheels, is chrome any good?
[Re: maximus]
#1815241
04/30/15 10:43 AM
04/30/15 10:43 AM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have had mine for about 6 years now. The car sees 1,500 miles or so a year, is stored inside and the only water it sees is when it is washed. Rust is trying to pop through in several spots on every wheel. The chrome is nice and shiny. The rust seems to be coming from behind the chrome.
There was a picture on one of these websites a few years ago that purported to show stacks of rusty bare steel wheels getting ready to be chromed. Whoever posted it said that the wheels were not prepped with any care (if at all) and were chromed with rust and such in place.
Cragars will look good for a while, but from what I have seen, they eventually start rusting in the corners and grooves. No matter how good you take care of them.
Master, again and still
[Re: maximus]
#1815253
04/30/15 10:59 AM
04/30/15 10:59 AM
Posts: 6,563 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I've been considering a set also. They have a one piece chromed aluminum wheel again which should solve the rust problem plus they are drilled 5x4.5 so no unilug BS. Whether the chrome stays on the aluminum any better IDK. I do hear of out of round and runout horror stories tho but that is with the 2 piece wheels. Kevin
[Re: Pynzo]
#1815286
04/30/15 11:36 AM
04/30/15 11:36 AM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
I have a set of the one piece polished S/S wheels, 15x7 up front and 15x8 rear. I love them. I put McGard lugs on too- nothing will rust! Pretty sure that's because that wheel is all aluminium ... Weren't the wheels being disgused in the thread alum. center with a steel band or is that the Keystone Klassics only?
[Re: JohnRR]
#1815302
04/30/15 11:55 AM
04/30/15 11:55 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Pretty sure that's because that wheel is all aluminium But not the lug nuts- I've seen many cheapo rusty lug nuts before- McGards have a lifetime warranty
[Re: OzHemi]
#1815423
04/30/15 02:21 PM
04/30/15 02:21 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The wheels are not made in mexico, but the chrome work is done there. They truck them from the plant in Ontario here down and back up again. The company has had numerous issues with the different platers they use and it still seems to be on going. Turn around order time on plated products from them is like 6+ weeks at the moment...
I deal with Carlstar (former Carlise) who make them on a regular basis...just was on the phone to them yesterday about my latest order of chrome steel outers actually...
And yes, even with bare components I get more then I should of quality control issues..very frustrating. Jeff, I'm looking at getting a new set of 15X8 and 15X12 Cragar S/S's, would it behoove me to have them dechromed electrostatically, then rechromed? is it possible to buy then in "raw" form, then have them chromed? FYI...I'm familiar with the need to "cure" them after chroming to avoid Hydrogen embrittlement Mike
[Re: maximus]
#1815547
04/30/15 04:30 PM
04/30/15 04:30 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
They keep changing platers, have issues with some, go to others, etc, etc. So always seems like a roll of the dice what you get, and with the long lead time it doesn't help either. I do not believe they will sell the S/S in raw form. They don't want to sell components of them either, I have tried to buy only the centers in the past.
As for stripping and rechroming them...I don't doubt you wouldn't get a better quality chrome job from a dedicated place, but if it is worth the cost... hard to say?
Sort of hard to know what the chrome work will hold up like on them out of the box until you've had them a little while. You could always inspect them first off and see just how good it is.
I know I just had an entire pallet of defective chrome 14" x 7" outers, and a bunch of bad 15" x 8" as well...
[Re: JohnRR]
#1815550
04/30/15 04:31 PM
04/30/15 04:31 PM
OzHemi
Garden Grove, CA
The classic/original S/S wheel is a composite steel/aluminum wheel as well...
[Re: maximus]
#1815691
04/30/15 06:49 PM
04/30/15 06:49 PM
OzHemi
Garden Grove, CA
No problem Mike !
I am trying to get them to be sure and inspect all of the chrome I get before wrapping the pallet up this end. The bad pallet of 14" outers wasn't noticed until it got to Oz and my buddy went to pull a few off to sell and found they were all defective. And order before that I had a bunch of bad ones too, poorly polished before plating, blistering, peeling, etc.
I had some bad 16" ones too..they were "raw" I ordered but when I was unstacked the pallet this end to squeeze them in the container, turned out I had 3 or 4 of them that were chrome outers someone had run over with a 60 grit disc it looked like and tossed in with the raw stuff...
[Re: maximus]
#1815714
04/30/15 07:10 PM
04/30/15 07:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
How old?
I bought some in 88 and never had rust issues, but that was a long time ago.
[Re: maximus]
#1815742
04/30/15 07:59 PM
04/30/15 07:59 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I have experience with the older Cragars and don't know much about the new ones.
The problems I hear of the nooks and crannies rusting first tells me that it's a prep issue. No doubt they take the raw wheels Oz showed and do a quickie blasting to clean them for chrome.
There's no good way to get down inside the crevices of a welded steel wheel in order to remove rust. Any rust between the center and outer of the wheel gets covered by the initial plating. If the plating does not take well in that crevice the rust will slowly grow until it pops the initial plating off the steel. That's when more oxygen gets to it and the growth takes off.
The plating can be sufficient to smother existing tiny rust accumulation but it's no guarantee.
The plating is likely done in Mexico to get around the EPA's ultra strict requirements. Obviously, labor is much cheaper there as well.
[Re: maximus]
#1815759
04/30/15 08:16 PM
04/30/15 08:16 PM
Supercuda
About to go away
About to go away
up yours
That is crappy OZ, guess I should of kept the old ones I had.
