Hi guys I got everything to assemble my 440(first big block build) and I was wondering what the horsepower/tq will be? Heres the set up:
-440 with 6pack pistons,rods,forged crank, deck milled, 10.3 compression
-Solid roller camshaft
Duration @ .050 (Int/Exh): 243/249
Gross Valve Lift (Int/Exh): .578/.585
LSA/ICL: 110/106
-Heavy ported 213 heads with stock valves(not sure on the flow)
-Street dominator intake with a thermoquad or holley 950DP
-2" primary, 3.5" collector fenderwell headers
Keep in mind im at 5500ft and would love to run in the 12s in my 3250lb dart with a 4500 stall and 3.73 gears!
