Re: pics of my bearings for the 408
[Re: mopar dave]
#1814665
04/29/15 05:15 PM
04/29/15 05:15 PM
BradH
Well, I'm curious what you're talking about, too.
As far as I know, every fluid pumping system is going to have flow limitations set by the size (restriction) of the passage(s), the viscosity of the fluid being pumped, the max free-flow volume of the pump, the max volume of the pump working against some set pressure (a product of the fluid's viscosity and that restriction), and any pressure-based blow-off limitation built into the system.
If the existing pump is already pushing the max capacity of fluid given the system's internal restrictions, and in the processs also hitting the peak pressure estabilished by the blow-off mechanism, then the only thing another pump could do differently is create more pressure from using a higher blow-off setting. However, the volume of fluid wouldn't increase signficantly past a certain point due to the limitation mentioned above.
Volume improvements under that scenario would need to come from enlarging the internal passage, not from trying to force-feed more oil through the same size passage.
[Re: Porter67]
#1814783
04/29/15 08:22 PM
04/29/15 08:22 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
MRL Performance. I agree and know nothing more than I already mentioned. I think melling is a great pump but there is better. Titan but do I want to spend $800 for it. No. The pump mike has is said to be easier on bronze gears and is worth a few hp and feeds oil depending on rpm. I built this engine and best machine did most of the machine work. It went 8 years with 40 to 50 passes and some street miles.
[Re: mopar dave]
#1814786
04/29/15 08:31 PM
04/29/15 08:31 PM
mopar dave
Mt Morris Michigan
Not claiming to be a pro engine builder. Just a hobbies with 6 engines built and no major failures. My tools are not the most expensive but get the job done. Craftsmen. My knowledge comes form this site as well as mopar performance books and other professional engine builders. The engine block and all components are getting checked and machined properly. Nothing gets throw together in my garage without getting checked and machined.
[Re: mopar dave]
#1814878
04/29/15 10:03 PM
04/29/15 10:03 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't out-trick yourself with trickery. I just took my engine apart after four years (2 years pump gas, 2 year alcohol) and my bearings looked GREAT. 35 dollar melling standard volume, standard pressure pump.
[Re: pittsburghracer]
#1814885
04/29/15 10:12 PM
04/29/15 10:12 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
To add to this I will never use a Canton oil pan on my small block again without modifying it. I bought one after seeing how nice the small block Chevy one was when I built an engine for a Friend. The Mopar one was a piece of JUNK compared to it and my oil pressure was dropping like a turd when I left the line. I put it on hoping it would give me more room than my Milidon did with the 1 7/8 Hedmen headers so I could use a diaper. NEVER again and thank God for my Racpak or I may have not caught it.
[Re: mopar dave]
#1814930
04/29/15 11:05 PM
04/29/15 11:05 PM
Posts: 9,859 MI, usa
dvw
MI, usa
.002 on both rods and mains. Used main studs. Had a local shop hone the mains. Eagle forged crank and rods. Moroso pan. Don't know how it was balanced but the guy that did it has a great rep. Brad Penn oil and now amsoil dominator 15/50. How much pressure? To me .002 with 15/50 is tighter than I would run. Personally most of my stuff is about .0027-.0029 and I run 5w30. Doug
[Re: mopar dave]
#1814938
04/29/15 11:15 PM
04/29/15 11:15 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Dave.... Did you say you used the Melling pump that a company called Precision blueprints? Ran one of them in my old W5 motor and thought it was up to snuff. I would be extremely suspect of a 180 dollar miracle oil pump, as I am sure you are as well.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
