Re: Flat tappet cam break in, 69 Charger with a 440
[Re: dssaa]
#1814383
04/29/15 01:39 AM
04/29/15 01:39 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I pull the dist and run the oil pump with my primer shaft before I start them to get oil flowing everywhere. I also add a bottle of the zinc additive. Ron
[Re: dssaa]
#1814384
04/29/15 01:46 AM
04/29/15 01:46 AM
Posts: 628 Denison,Ia.
Cuda367
Denison,Ia.
You want it ti start as fast as possible although I never do one without priming first.
[Re: 383man]
#1814410
04/29/15 02:57 AM
04/29/15 02:57 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just my 2-cents, but I've never lost a flat tappet cam......
Run the pump with a drill on a priming rod while you rotate the crank a few times by hand (need a buddy for this). Make sure you've got pressure at the guage, and you're getting oil to all rockers. Should be able to button it up at that point, and start it. As soon as you get it running, get the idle up around 2k, and let it run there for a few minutes. watch the temp guage. If it runs past normal operating temp, back some timing out, or fatten it up a little and see where that gets you in regards to temp. IMO: Carb should be jetted OTB for this process.
New motors smell funny! good luck.
[Re: dssaa]
#1814542
04/29/15 01:08 PM
04/29/15 01:08 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Go with a break in oil formulated for flat tappet cams. After break in, go with a specially formulated oil for flat tappet cams as well. Additives may work 99 percent of the time. But there can be conflicts when mixing additives and oils, and a few are not compatible. I avoid it when I can. The main thing is to make sure those lifters rotate when you turn the motor over before firing. Did your engine builder check? If they don't rotate a little, that MUST be corrected. They don't need to move much at all, but they have to turn to live. Mark all lifters a 12 oclock with a felt tip, and turn the motor over a couple of revolutions. It is simple to fix one that doesn't rotate, just remove the lifter that is not rotating, put some 500 grit sand paper in the palm of your hand and rotate the base of the lifter against it till the shine goes away. Clean, and reinstall. Recheck, and fire the motor.
[Re: Porter67]
#1816028
05/01/15 01:34 AM
05/01/15 01:34 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Well I can say that I have wiped out a few solid lifter cams in my 45 years of building big block mopars. So there, I said it, I learned from my mistakes from not looking for lifter rotation, not pre -priming the engine, not having the timing set right on so the engine would fire right off, not pre-priming the carb with gas, not removing the inner springs to reduce pressure on the cam, not having the battery fully charged and there's probably a few more items. I know now that when I turn the key the engine will fire up so fast it's almost scary.
[Re: dogdays]
#1816371
05/01/15 02:36 PM
05/01/15 02:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Stock engines rarely had more than 100lb seat pressure. That IMHO counts for a lot, and is probably the reason the engines ran without cam breakin, or at the most, a couple of minutes.
R. When a car comes off the line the driver gets it out of there and either heads for the parking area(which can be a couple of miles) or it heads to the rail yard and in most cases it goes right onto the rail car.. all in all they beat on them for about 10 minutes or a bit more
[Re: RemCharger]
#1816391
05/01/15 02:49 PM
05/01/15 02:49 PM
Porter67
Maybe I typed that wrong or azz backwards, but it was from a builders point of view as well, I do 4-5 a winter for various applications and I know if I wipe a cam or they do I need to make sure I did everything I could to prevent it because if it happens, at the end of the day it sucks for everyone. But for some reason it seemed that maybe around the 60k mark a lot of the mopars I had bought used were ready for a new cam. That's when we all thought if a car had turned over the 100k mark it was junk and really for the most part the front ends/motors,trans were all needing attention by then. Very true Mr P but ive seen some crazy stuff from dealerships. Back when the semi fast grand national buicks were in a friend from the detail shop used to swing by my work and take me for a test thrash and when I had my 86 gn I was looking for a 5.0 lx and told the salesman if it could hang with the Buick id buy it and we spent an hour on the interstate while he tried to sell the car but it fell short, only to find out a fella in our street race group bought the same car a week later. But I never could tell him his lx was pre thrashed. Sorry to go off topic. A wiped cam means a full teardown on the builders dime which many try to avoid.
A customers point of view!
