noisy engine on startup Hemi #1813535
04/27/15 11:54 PM
04/27/15 11:54 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I have a 2006 1500 with a Hemi. Just today started engine and it was noisy like no oil pressure. Looked at gauge and had good pressure. Noise lasted about 20 seconds and went away.. Oil level good. Oil was changed about 1000 miles ago. Does this engine have an oil pressure timing chain tensioner? What's your thought
Re: noisy engine on startup Hemi [Re: moparmikethree] #1813550
04/28/15 12:12 AM
04/28/15 12:12 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What brand of oil filter was put on?
Re: noisy engine on startup Hemi [Re: moparmikethree] #1813551
04/28/15 12:13 AM
04/28/15 12:13 AM
Purolator. What should I use
Re: noisy engine on startup Hemi [Re: moparmikethree] #1813597
04/28/15 12:59 AM
04/28/15 12:59 AM
I had a later (81 up) hyd lifter /6 that would do that same exact thing regularly. psi was VG. Would come and go randomly & I noticed it when starting. I just assumed it was a bad lifter or two
Re: noisy engine on startup Hemi [Re: RapidRobert] #1813698
04/28/15 04:25 AM
04/28/15 04:25 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
possibly exhaust manifolds leaking?
Re: noisy engine on startup Hemi [Re: mopars4ever] #1813831
04/28/15 12:59 PM
04/28/15 12:59 PM
mr norms avenue
5571 Offline
5571  Offline
mr norms avenue
I had an issue with one of my cars yrs ago (chevy Tahoe) and learned some oil filters have a valve to not allow oil to flow out when the car is off.
Since then, I have noticed the better filters have this feature (even on my ford focus). I doubt the cheaper filters have it.
My Tahoe was a bit quieter on startup, when I went with the good filter. It keeps some top end training I think. Or it keeps the filter from draining.
67 hemi GTX silver 4spd, 70 cuda convert 340 4spd, 71 cuda 340 4spd (Curious Yellow, white billboards/interior), 70 Mr Norm's Challenger 440 4spd
Re: noisy engine on startup Hemi [Re: 5571] #1813864
04/28/15 01:53 PM
04/28/15 01:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check your exhaust manifold to head bolts. They are noted for snapping off on the 5.7.
Re: noisy engine on startup Hemi [Re: moparmikethree] #1813874
04/28/15 02:17 PM
04/28/15 02:17 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'd put a mechanical oil pressure gauge on the motor and watch it during start up, so as to rule out the noise truly being lack of oil pressure at start up. Good insurance, regardless. Purolator should have an anti drain back valve and is what I would consider a good filter.
Re: noisy engine on startup Hemi [Re: moparmikethree] #1813920
04/28/15 03:14 PM
04/28/15 03:14 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I have an '05 1500 with Hemi. I've always thought my engine was noisy on cold start up. Like you, the nosie lasts about 20-30 seconds then goes away.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: noisy engine on startup Hemi [Re: 69CoronetRT] #1813953
04/28/15 03:51 PM
04/28/15 03:51 PM
Washington/Las Vegas
1971 Gran Coupe Offline
This has been an interesting topic to follow. I have a vehicle and always used Napa Gold filters. Was in a hurry one time and picked up another brand and it started doing exactly what has been described of a noisy start-up and dissipated within a few moments. With all this in mind, I suspect the cheaper oil filter.work Good stuff here as usual.
thanks
Re: noisy engine on startup Hemi [Re: moparmikethree] #1813972
04/28/15 04:13 PM
04/28/15 04:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are you running 5w20? Anything else can raise hell with the multiple displacement stuff in the lifters.
Kevin
Re: noisy engine on startup Hemi [Re: moparmikethree] #1814281
04/28/15 11:23 PM
04/28/15 11:23 PM
Yes I'm using the 5-20. When I first got it there was a code for incorrect oil weight.. So I'm careful of what I use
