Page 1 of 3 1 2 3
2nd place in class at BBORR - video #1813944
04/28/15 03:43 PM
04/28/15 03:43 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Finished 2nd out of 11 or 12 in the 135 mph average class - we averaged 135.010 mph (.225 seconds off target). Stopwatch only.
Got the car up to 161 mph for a bit (2:24 in youtube video). Water temps went to 243*F at the end of that long straight.
My gearing is poor for this event - shifted to 5th at 125 mph at 3800 rpm and left it. Never made it over 5,000 rpm.
Enjoy.
https://youtu.be/9dJD4RmxXGE
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1813971
04/28/15 04:11 PM
04/28/15 04:11 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Awesomeness...
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814004
04/28/15 05:05 PM
04/28/15 05:05 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Thanks Tom
Now to figure out a solution to get the coolant temps down. Can't run a faster class if I'm cresting 240*F everytime I go over 160 mph. Talked with AFCO, got some ideas. The radiator I'm running is used in 700-800 hp dirt track cars with bad airflow.
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814027
04/28/15 05:56 PM
04/28/15 05:56 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Awesome Wade, that is a serious accomplishment. I have wondered about the effect of cooling at speed, my car has always struggled with it at speed even over 80-85 mph. Almost think its a trapped heat issue in the engine compartment. I know airflow is there in spades because when I first put my glass lift off hood on with no center rear hood pin, first pass down the quarter it turned into an umbrella at the rear. Lesson learned, but now where does all that air pressure go?
Mopar to the bone!!!
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814044
04/28/15 06:19 PM
04/28/15 06:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I seem to run cooler at higher speeds from 80-130.
I wonder if it has to do with the grill opening, shape, and obstructions?
I have a lower valance and get air from under the bumper between the valance too.
I've considered blocking off part of the grille opening for aero until I see a heat rise.
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814055
04/28/15 06:36 PM
04/28/15 06:36 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
A friend brought up a point I haven't considered:
Why not just leave the electric fan on? I've got it programmed to not run at 30% TPS or greater. The temps would drop in the corners at BBORR - well that partially might be because the fan was coming on.
Obviously the fan solution isn't fixing the root of the problem, which is a lack of a pressure differential great enough to cause significant airflow.
Potential problems causing the lack of a pressure differential:
- 1" gap between hood and top radiator crossmember
- hood is not sealed to body at all
- hoodscoop
- holes in front radiator crossmember (behind the parking lights)
- AC condenser in front of the radiator (apparently needs to be 3/4"-1" away from radiator)
- Oil cooler in front of AC condenser (only behind the bumper - ran 240*F oil temps, btw)
Things I've done:
-lowered the lower radiator crossmember (and extended it to the sides with an airdam)
-Sealed the front airdam / splitter to the bumper
-sandwiched foam between radiator and radiator crossmember
-sealed a couple small holes in the radiator crossmember
BTW - I checked my temps from a recent TWS track day. Never got over 220*F. I also ran a session without the fan in the car - temps were nearly identical.
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814064
04/28/15 06:49 PM
04/28/15 06:49 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Post-race. tons of bugs. car was clean before the 118 mile round trip. Shows the air-dam and splitter. Which did a great job of keeping the front end down at high speed.
General location of the coolers:
Unlimited class cup car hit a buzzard at 160-180 or so. Finished the race looking out the passenger side of the windshield!
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814070
04/28/15 07:00 PM
04/28/15 07:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's a lot of stuff in front of the radiator.
Need to seal top of radiator support to hood.
Maybe experiment with plugging air scoop.
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814108
04/28/15 07:58 PM
04/28/15 07:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Shim the back of the hood up so that there is a gap and see if that releases trapped air under the hood at high speed. If so you know you have an airflow "out" issue not an "in" issue going on.
Don't be the exception.
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814282
04/28/15 11:24 PM
04/28/15 11:24 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
I would think you want the seal between the core support and the hood to force the air to go through the radiator, not over. I would try that first.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814309
04/29/15 12:06 AM
04/29/15 12:06 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I wouldn't be surprised if the scoop is the culprit, I have same one, but I absolutely MUST run my fans at freeway speeds. Air comes through radiator then what?
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814310
04/29/15 12:10 AM
04/29/15 12:10 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I also sealed my core support to hood with garage door seal. That was worth probably 10 degree drop. Wade that oil cooler is freaking hilarious dude!
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814315
04/29/15 12:14 AM
04/29/15 12:14 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
at 160 mph a lack of seal between the hood and radiator support isn't an issue. Remember, what does in has to go out and if it can't get out, it can't get in either.
Re: 2nd place in class at BBORR - video [Re: 72Swinger] #1814328
04/29/15 12:32 AM
04/29/15 12:32 AM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
I told you it was huge! Hide it behind the bumper with no airflow and it STILL keeps it cool.
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814330
04/29/15 12:33 AM
04/29/15 12:33 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You just had to one up me on oil cooler girth didn't ya! LOL!
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814413
04/29/15 03:27 AM
04/29/15 03:27 AM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
Awesome video and great car. I did one of the defunct nevda events years ago. Grerat fun and i hope to get my Challenger to one in the very near future.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814520
04/29/15 12:27 PM
04/29/15 12:27 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Awesome! I also wonder about the ability for air to exit the engine compartment contributing to your problem. This is inspiring to watch..
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814573
04/29/15 02:25 PM
04/29/15 02:25 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Wade is there any way to have the front spoiler force some air right up into the front of the radiator? Wouldn't take much area to force a bunch of air through at high speed. That's what the C5 Vette uses, about 12 inches, but you shouldn't need that much...
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1814630
04/29/15 03:49 PM
04/29/15 03:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
In my opinion, some of you are looking at it the wrong way. Others are closer.
Too much air under the hood.
Instead of helping the air get out you need to limit how much is getting in.
You want a low pressure area in the engine compartment. Doing that will force the air through the cooling package.
Run your next high speed event with the hood scoop taped off. Your engine will draw hot under hood air but you will likely see the radiator temps drop. That's a cheap test that only costs a few strips of duct tape.
Any air coming in contact with the core support and cooling package needs to be handled. The air is stacking up and looking for somewhere to go. You can add paneling/baffles behind the grille to direct air into the cooling package. If so, make it narrower at the entrance than it is at the radiator. Air is more likely to be "trapped" and not spill out over the sides. This helps create a higher pressure area in front of the radiator.
A seal between the core support and hood would eliminate flow up there. I wouldn't hurt to add an under cover extending from the air dam to the back of the engine compartment.
Raising the back of the hood and doing other things to help air get out is essentially treating the symptoms, not the problem.
Air flow is often thought of as fluid movement. Use fluid. Put the car in high speed trim and block off the back side of the radiator. Grab your garden hose and spray the front of the car. The water will go where the air goes. Block off anything that allows the water to get to the engine compartment. Doing that will find your areas of concern. The scoop will be a big culprit. Check the air moving over the top of the bumper too.
- Stu Harmon
Re: 2nd place in class at BBORR - video [Re: Uhcoog1] #1815109
04/30/15 01:57 AM
04/30/15 01:57 AM
Lubbock, TX
slantvaliant Offline
Lubbock, TX
Enjoy.
Here's the view of your car from Gate 43 (about 15:16 in your video - 150 MPH)
Page 1 of 3 1 2 3
