removed ralley cluster and lost power
#1812846
04/27/15 03:14 AM
04/27/15 03:14 AM
Posts: 23 SoCal
droptail
SoCal
Hello everyone,
I want to test signal going into tach but car won't start with cluster removed. Can't car run with I/P removed? I don't seem to have any power at all, although I have battery power at starter relay.
' '70 Cuda convt - 383 bored/ported, Hemi cam, Rhoads, rollers, Mellings, MSD, 750 DP, LT dual 3", lowered, snubber, police chuck, discs, springs, sway bars, Transgo, posi, shaker, aluminum 17" rallyes w/275-285/40 EXTREMECONTACT SPORT, leather...
Re: removed ralley cluster and lost power
[Re: OzHemi]
#1812988
04/27/15 01:10 PM
04/27/15 01:10 PM
RapidRobert
Welcome aboard! Oz has you covered. ALWAYS a good caveat to pull a batt cable off BEFORE you start up under there.
[Re: RapidRobert]
#1813156
04/27/15 04:29 PM
04/27/15 04:29 PM
Posts: 23 SoCal
droptail
SoCal
Welcome aboard! Oz has you covered. ALWAYS a good caveat to pull a batt cable off BEFORE you start up under there. I did, then reconnected to obtain tach signal. Seems lead changes from Gray/black in engine compartment to BLue and White red at I/P. I have (2) leads for each Ammeter post (total 4 leads to ammeter), is this correct? Just connect all (4) together? Thanks
