removed ralley cluster and lost power #1812846
04/27/15 03:14 AM
04/27/15 03:14 AM
SoCal
droptail Offline OP
droptail  Offline OP
SoCal
Hello everyone,
I want to test signal going into tach but car won't start with cluster removed.
Can't car run with I/P removed?
I don't seem to have any power at all, although I have battery power at starter relay.
' '70 Cuda convt - 383 bored/ported, Hemi cam, Rhoads, rollers, Mellings, MSD, 750 DP, LT dual 3", lowered, snubber, police chuck, discs, springs, sway bars, Transgo, posi, shaker, aluminum 17" rallyes w/275-285/40 EXTREMECONTACT SPORT, leather...
Re: removed ralley cluster and lost power [Re: droptail] #1812859
04/27/15 03:53 AM
04/27/15 03:53 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You need to connect the ammeter wires together..the power runs through there, with cluster out, just connect them together and you'll be set.
Re: removed ralley cluster and lost power [Re: OzHemi] #1812988
04/27/15 01:10 PM
04/27/15 01:10 PM
Welcome aboard! Oz has you covered. ALWAYS a good caveat to pull a batt cable off BEFORE you start up under there.
Re: removed ralley cluster and lost power [Re: RapidRobert] #1813156
04/27/15 04:29 PM
04/27/15 04:29 PM
SoCal
droptail Offline OP
droptail  Offline OP
SoCal
I did, then reconnected to obtain tach signal.
Seems lead changes from Gray/black in engine compartment to BLue and White red at I/P.
I have (2) leads for each Ammeter post (total 4 leads to ammeter), is this correct?
Just connect all (4) together?
Re: removed ralley cluster and lost power [Re: droptail] #1813226
04/27/15 06:16 PM
04/27/15 06:16 PM
Andrewh Offline
Andrewh  Offline
I have never seen 4, but yeah. otherwise you will lose power to probably seats and top.
