Re: Equipment label.
[Re: savoy64]
#1813123
04/27/15 03:50 PM
04/27/15 03:50 PM
Posts: 248 Amarillo, Tx
ramblebee
Amarillo, Tx
i am looking too---who made the fuzzy label? We'll I don't like dropping anyone in the dirt but in an effort to help you and others, I had Skip Gibbs make the first one. It is very fuzzy and incorrect. He gave it a good try though.
[Re: ramblebee]
#1813135
04/27/15 04:02 PM
04/27/15 04:02 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
You can get blank ones from Dodge Connection then you can print it out yourself using a printer. I have done it, its not easy but with a little patience and practice you can do it
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
[Re: adventurer]
#1813170
04/27/15 04:44 PM
04/27/15 04:44 PM
ramblebee
Amarillo, Tx
You can get blank ones from Dodge Connection then you can print it out yourself using a printer. I have done it, its not easy but with a little patience and practice you can do it That may be the way I have to go. Im not the most computer literate person and fear I will have a fortune in blanks.
[Re: ramblebee]
#1813313
04/27/15 08:06 PM
04/27/15 08:06 PM
adventurer
Print it out on regular paper first and size it and do all your edits before printing. Hold the label up behind it in the light and you can see where everything lines up. Then when you think you have it just right, print it on the label, be sure when you do print it on the label allow it some drying time because they don't take the ink real well and are easy to smear.
