best tie rod end for 69 b-body?? strut bars? #181281
01/02/09 02:52 AM
01/02/09 02:52 AM
long island
autodynamics Offline OP
long island
ive done some homework on tie rod ends for my charger. right now i have the factory ones and want to replace them with better ones. hotckos makes some but are not greaseable. firm feel makes a nice set as well as does just suspensions. i need your input on these products, if you guys have used them. also same goes for the strut bars. a spoke to dick at firm feel once and said it was not necessary to change the as the change was'nt huge.. what do you guys think??? thanks in advance
Re: best tie rod end for 69 b-body?? strut bars? [Re: autodynamics] #181282
01/02/09 07:26 AM
01/02/09 07:26 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I yet to have anyone convince me that going to 11/16" tie rods makes a "real" improvement. And if "11/16" is such a big deal, why hasn't anybody gone to 3/4" or 1"??? On strut bars they mainly IMO offer robustness when braking or hitting potholes, both not a critical improvement with upgraded bars, but there is always the follow the herd and bling factors to consider.
Re: best tie rod end for 69 b-body?? strut bars? [Re: jcc] #181283
01/02/09 09:04 AM
01/02/09 09:04 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
I had my Kframe out and was swapping to disc brakes, so I upgraded my front suspension. I used Just Suspension tierods with the rest of the street/strip kit. We will see when I put more miles on in the spring what the real difference is I am happy with the suspension kit install and components. And it worked will with my off the shelf parts disc brake upgrade.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: best tie rod end for 69 b-body?? strut bars? [Re: moepwr] #181284
01/02/09 01:18 PM
01/02/09 01:18 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
If you are rebuilding your front suspesion anyway, the cost to move up to 11/16 is minimal and certainly worth the trouble. They were the standard size for the heavier C bodies and they will flex less on the B's. Every little bit helps.
Re: best tie rod end for 69 b-body?? strut bars? [Re: Lee446] #181285
01/03/09 12:16 AM
01/03/09 12:16 AM
long island
long island
my suspension is all done and complete but its been haunting me for a while looking into it but really is there a differnce? what about the hotchkis ones there the most money with no grease fittings. or are other ones better?/
Re: best tie rod end for 69 b-body?? strut bars? [Re: autodynamics] #181286
01/03/09 12:54 AM
01/03/09 12:54 AM
AndyF Offline
AndyF  Offline
If you need new tie rod ends just buy the C body ones. They cost the same (sometimes less) and they are bigger and beefier. You need to get the correct adjuster tube at the same time. Look thru the parts book and select the correct length, there are 3 or 4 different lengths for the adjuster tubes. You can also buy the solid type adjuster tubes from Firm Feel for a little extra money.
Re: best tie rod end for 69 b-body?? strut bars? [Re: AndyF] #181287
01/03/09 02:41 PM
01/03/09 02:41 PM
808CUDA Offline
808CUDA  Offline
Hey Pete! How are you doing buddy?!
I went all Firm Feel on the front end on my '71 Cuda duing the 6.1 Hemi swap.
Quality parts and excellent service from Dick and Dennis
I went with the 11/16" tie-rod combo set since I was starting from new. If you already rebuilt the suspension, I really doubt you will feel any difference with the 9/16" tie-rods you have already.
if you got the $175 burning a hole in your pocket and want the piece of mind, go ahead and get the FF's set-up. Best priced set on the market. If not, wait till you need to do your front end and then swap em out.
Here's a few pics of my Firm Feel parts
Re: best tie rod end for 69 b-body?? strut bars? [Re: 808CUDA] #181288
01/03/09 02:42 PM
01/03/09 02:42 PM
808CUDA Offline
808CUDA  Offline
Another pic...
Re: best tie rod end for 69 b-body?? strut bars? [Re: 808CUDA] #181289
01/03/09 02:42 PM
01/03/09 02:42 PM
808CUDA Offline
808CUDA  Offline
boxed lower control arms...
Re: best tie rod end for 69 b-body?? strut bars? [Re: AndyF] #181290
01/03/09 02:47 PM
01/03/09 02:47 PM
CHRGR69 Offline
CHRGR69  Offline
How little??
Grandma always said I had "hands of gold"!
Re: best tie rod end for 69 b-body?? strut bars? [Re: 808CUDA] #181291
01/03/09 04:01 PM
01/03/09 04:01 PM
long island
long island
hey..... whats up...??? the only reason why i was going to swap them out is because i dont like the way they look and i want them to be powder coated. like the rest of my stuff.. i have the original strut bars in also. but dick had had to me not to change them. im a little hesitant in changing them because my alignment is so good. but when the chance comes up im gonna swap them out.. for which ones? the 9/16 ones??
Re: best tie rod end for 69 b-body?? strut bars? [Re: autodynamics] #181292
01/03/09 04:05 PM
01/03/09 04:05 PM
808CUDA Offline
808CUDA  Offline
go 11/16" Pete
Your car is not original anyways
Re: best tie rod end for 69 b-body?? strut bars? [Re: 808CUDA] #181293
01/03/09 05:29 PM
01/03/09 05:29 PM
long island
long island
have you done the fatman drop spindles??? anyone??
Re: best tie rod end for 69 b-body?? strut bars? [Re: autodynamics] #181294
01/03/09 06:24 PM
01/03/09 06:24 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I just bought a full front end replacement for my Coronet from Rock Auto using all Moog parts. It is not a kit you just order each part. Total cost shipped for everything was 376.55
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
