Switched to synthetic oil and have a question. #1811958
04/25/15 11:17 PM
04/25/15 11:17 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I just switched over using from conventional Chevron brand motor oil in the road runner to 20w/50w Royal Purple's full synthetic type as I got a good deal on some.
So I drove the road runner about 20 miles and then rechecked the oil and went from a nice clean color to really dark color in that short amount of usage.
Just wondering if this normal when switching to a full synthetic?
work
Stu
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812046
04/26/15 12:32 AM
04/26/15 12:32 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That's not been my experience but I use Mobil 1 and I have only switched over modern EFI engines.
I haven't switched a carb'ed engine.
Kevin
Re: Switched to synthetic oil and have a question. [Re: Twostick] #1812060
04/26/15 12:46 AM
04/26/15 12:46 AM
Maybe it grabbed all the dirt of the internals right away?? That was my first thought? shruggy
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812062
04/26/15 12:50 AM
04/26/15 12:50 AM
Kirkland, Washington
Pacnorthcuda Offline
That's likely exactly what happened. Your new oil probably has more/different detergents than your previous oil.
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812063
04/26/15 12:51 AM
04/26/15 12:51 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Maybe
How'd yer 'old' oil look???
Re: Switched to synthetic oil and have a question. [Re: RSNOMO] #1812075
04/26/15 01:12 AM
04/26/15 01:12 AM
Maybe
I always change the oil once a year and as usual it was just getting sort of dirty looking. Usually it stays pretty clean for most of the year. I would guess i put on about maybe 1000 miles to 1500 miles between oil changes.
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812128
04/26/15 04:38 AM
04/26/15 04:38 AM
Riverside, California
ghostrider Offline
ghostrider  Offline
I know Mobile1 does that real quick in lots of engines, not sure about RP.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
Re: Switched to synthetic oil and have a question. [Re: ghostrider] #1812159
04/26/15 09:41 AM
04/26/15 09:41 AM
So this is normal i guess? Wonder if i should change it again right away if its full of contaminates now? work
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812169
04/26/15 10:06 AM
04/26/15 10:06 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I wouldn't.
Also if you change it every year at approximately 1500 miles, then synthetic is a waste of money for you. Use regular oil or extend your oil changes to like 7500 miles to make synthetic worth while. IMO
Re: Switched to synthetic oil and have a question. [Re: Challenger 1] #1812180
04/26/15 10:26 AM
04/26/15 10:26 AM
I only used the Royal Purple as i got a deal on it from a friend so it was going to be the same cost as regular. The car sits so much that i feel changing the oil every year is worth the few $$.
beer
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812321
04/26/15 02:33 PM
04/26/15 02:33 PM
W
Wagonman1967 Offline
W
Isint that Royal Purple uh Purple? IIRC it is dark to begin with.
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812344
04/26/15 03:14 PM
04/26/15 03:14 PM
Andrewh Online content
Andrewh  Online Content
I remember royal purple didn't stay purple for long. been a while though.
I also agree. I change my oil once a year too. 30 bucks in oil and filters once a year is cheap insurance, for as little as I drive mine.
I wouldn't worry about changing it early just for a color change.
oil sample tests are as expensive as a change, so I probably wouldn't bother with that either.
Re: Switched to synthetic oil and have a question. [Re: Challenger 1] #1812351
04/26/15 03:33 PM
04/26/15 03:33 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Agreed...
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812359
04/26/15 03:53 PM
04/26/15 03:53 PM
California High Desert
O
old chief Offline
old chief  Offline
O
I would be real careful using Synthetic in old muscle cars with flat tappet cams. Flat tappet cams REQUIRE an oil with Zinc in it. You really need a racing oil with Zinc, for instance, VR1 Valvoline, or Amsoil Dominator racing oil, Joe Gibbs racing oil. They have taken all the Zinc out of oils because it plugs up Catalytic Converters. I learned the hard way. At least put an additive with Zinc in it.
Re: Switched to synthetic oil and have a question. [Re: old chief] #1812364
04/26/15 04:05 PM
04/26/15 04:05 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
This might be an interesting read.
https://540ratblog.wordpress.com/
Re: Switched to synthetic oil and have a question. [Re: old chief] #1812371
04/26/15 04:21 PM
04/26/15 04:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I would be real careful using Synthetic in old muscle cars with flat tappet cams. Flat tappet cams REQUIRE an oil with Zinc in it. You really need a racing oil with Zinc, for instance, VR1 Valvoline, or , Joe Gibbs racing oil. They have taken all the Zinc out of oils because it plugs up Catalytic Converters. I learned the hard way. At least put an additive with Zinc in it.
There are synthetic oils that have high anti-scuff additives (zddp/zinc or others).
"Amsoil Dominator racing oil, Joe Gibbs racing oil." are synthetic.
Re: Switched to synthetic oil and have a question. [Re: 65Fury440] #1812575
04/26/15 10:05 PM
04/26/15 10:05 PM
Central NC
gch Offline
gch  Offline
Central NC
Big thread on this guy on the corvette forum.Film strength test being taken as gospel without wear and other factors taken into consideration.One guy chellenges him pretty strongly.I will provide a link if anyone is interested.
Re: Switched to synthetic oil and have a question. [Re: gch] #1812616
04/26/15 10:48 PM
04/26/15 10:48 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Superior heat protection, no doubt...
But, regarding viscosity, I'm on the fence...
Re: Switched to synthetic oil and have a question. [Re: RSNOMO] #1812746
04/27/15 12:21 AM
04/27/15 12:21 AM
The Royal Purple oil i used has the added ZINC in it. up
Re: Switched to synthetic oil and have a question. [Re: MidPenMopar] #1812757
04/27/15 12:30 AM
04/27/15 12:30 AM
Texas
shart70rt Offline
shart70rt  Offline
Texas
Change the filter and add a quart. Using a high quality filter helps extend the life of synthetics, but you are not doing many miles anyway.
70 Go Mango Charger RT
White Vinyl Top
18 Spline 4 speed
Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing
505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
