2003 Dodge window regulator #1812545
04/26/15 09:13 PM
04/26/15 09:13 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I have a 2003 Dodge Quad cab and the electric window in the left rear door dropped clear to the bottom but didn't break.
My question is is there any way to get the window back up and stay in place without replacing the regulator ?
Re: 2003 Dodge window regulator [Re: flatiron] #1812872
04/27/15 08:05 AM
04/27/15 08:05 AM
Guitar Jones Offline
Well I've seen wood wedges, screwdrivers, knives, and duct tape used to hold windows up. I guess you could pick whatever hillbilly engineering process fits in with your local customs.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2003 Dodge window regulator [Re: flatiron] #1813495
04/27/15 11:12 PM
04/27/15 11:12 PM
Lehigh Acres, Florida
rickstershemi Offline
I would think you could pull the interior panel and get a look to see what the problem is...????
Rickster
Re: 2003 Dodge window regulator [Re: flatiron] #1816784
05/01/15 11:53 PM
05/01/15 11:53 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
do what rickster said--if you cant fix it-prop it up with a piece of 1x2--let the next owner deal with it...
