Another disc conversion question
#1811963
04/25/15 11:24 PM
04/25/15 11:24 PM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
Can you use the spindles from a 76 F body to do a disc conversion on a 66-72 B body? If so would I need the upper control arms and lower ball joints from the F body?
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
Re: Another disc conversion question
[Re: johnedod]
#1812156
04/26/15 09:33 AM
04/26/15 09:33 AM
Posts: 5,821 ohio
ruderunner
ohio
Yes, no need to change ball joints or arms. Fits 62 up b bodies. Note though you should use 1970 calipers for this.
For more details look up Mopar Action disc brake swap, covers all the details.
Angry white pureblood male
[Re: johnedod]
#1812336
04/26/15 03:04 PM
04/26/15 03:04 PM
Posts: 31,036 Oregon
AndyF
The knuckles will work fine and perhaps the calipers, just depends if you are hanging the calipers to the front or the rear. I'd recommend buying the taller 11.75 caliper adapters and using the 11.75 rotors. B body cars can use all the front brake that you can put on there. www.DoctorDiff.com will have all the parts you need for the conversion.
[Re: AndyF]
#1813110
04/27/15 03:39 PM
04/27/15 03:39 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
If I recall correctly there was some controversy in the past over using the F Body spindles over the Mopar Action/Rick Ehrenberg preferred 73-76 A body disc brake spindles, due to geometry issues. But, no one has brought that up, so maybe it is really a non-issue
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1813274
04/27/15 07:32 PM
04/27/15 07:32 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
If I recall correctly there was some controversy in the past over using the F Body spindles over the Mopar Action/Rick Ehrenberg preferred 73-76 A body disc brake spindles, due to geometry issues. But, no one has brought that up, so maybe it is really a non-issue It is a non-issue. We beat it to death back around 2001/2002. E-burg eventually relented that it is not an issue but refused to update his article to reflect the change.
