SS windshield trim removal/install questions #1811960
04/25/15 11:22 PM
04/25/15 11:22 PM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
Does a 73 runner or 73 charger front windshield trim fit a 71 runner? I have both at my disposal and they have nicer trim than what I got.
a) if yes, what is the best way of pulling of the trim without denting or wrecking it? ie do you start with one of the corner pieces first? or the big cowel where the wipers sit on?
b) whats the best way of installing said pieces?
Re: SS windshield trim removal/install questions [Re: dangina] #1811973
04/25/15 11:32 PM
04/25/15 11:32 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
I've used a tool like this: http://www.tooltopia.com/kd-tools-2038.a...CFZY0aQod6o8Agw You hook the clip with it and pull the clip away from the trim and lift the trim up. You probably should take the bottom piece off first. I THINK the trim is interchangable but I'm not 100% sure. You just press the trim back in place.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: SS windshield trim removal/install questions [Re: johnedod] #1812023
04/26/15 12:13 AM
04/26/15 12:13 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
yes they interchange and so does the rear but by 74 the rear changed to aluminum instead of stainless for some odd reason
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
