Does anybody here work with lead..
#181167
01/02/09 12:43 AM
01/02/09 12:43 AM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
Or whatever the substance is anymore. Not sure if "leading" is EPA approved but whats its' replacement? Is anyone doing it? I have thought that IF I build an old style street rod{ever}, I'd like to smooth the seams. Is it easier to just use mig,tig or the body panel glue. I like learning to do new things. I need to learn to Tig aluminum but I'd like to learn the lost arts too..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Does anybody here work with lead..
[Re: KatFysh]
#181176
01/05/09 11:07 PM
01/05/09 11:07 PM
Posts: 1,279 Buzzardbreath Wyoming
BigBird
Even if you lead a body seam you need to weld it or it will crack just as any filler would. Working lead takes practice like any skill. Done properly it will last a lifetime. Done poorly it is no better than plastic fillers.
