Re: Electrical Guru's ..3 speed wiper =..B Body
[Re: Slotts]
#1812150
04/26/15 09:01 AM
04/26/15 09:01 AM
Posts: 1,679 Mansfield,Ohio
moparrulzzz
Mansfield,Ohio
Sorry, that first post was more detailed and back breaking than simply trying this. Does your washer pump motor work? That will tell you right away if 12 volts is coming into the switch and across the internal breaker. Thnx for the info, it definately gives me a starting point on where and what to look for. Electrical is not my strong point. I did check for ground, wasnt that simple!! Thnx guys!!
