TRANNY HELP!! 45RFE #1811356
04/25/15 03:04 AM
04/25/15 03:04 AM
Fargo ND
moparphilll Offline OP
Fargo ND
OK here is what we have: 2004 Dodge Ram Quad 4X4 hemi 45RFE tranny
Here is what we did: Bought new tranny fluid and both Filters
removed pan removed spin on filter , replaced with new (filled before spinning on ) replaced l
flat filter with o ring put in 7 Qts fluid which indicates Full on dip stick;;; Started put in Neutral revved up a few times HAS NOTHING in D or R ????
Any ideas??
Re: TRANNY HELP!! 45RFE [Re: moparphilll] #1811453
04/25/15 11:47 AM
04/25/15 11:47 AM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
Did you check the fluid level with the engine running? Sounds like you just don't have enough fluid in the transmission. Don't think you need the transmission in neutral to check fluid levels like the older cars.
Good Luck,
Re: TRANNY HELP!! 45RFE [Re: bri440] #1811605
04/25/15 03:18 PM
04/25/15 03:18 PM
Fargo ND
Fargo ND
Filter seal loose problem solved boogie
Re: TRANNY HELP!! 45RFE [Re: moparphilll] #1812232
04/26/15 12:04 PM
04/26/15 12:04 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
I hope you drove the main sump filter seal into the pump. If you didn't the filter will fall out of the pump.
Re: TRANNY HELP!! 45RFE [Re: teflon] #1812821
04/27/15 01:45 AM
04/27/15 01:45 AM
Fargo ND
Fargo ND
That was it ! I just pressed it in by hand, and it fell out when I ran it... when we toke it apart it was out.
