Mild built 383 spark plug suggestion
#1810898
04/24/15 01:19 PM
04/24/15 01:19 PM
Posts: 320 Dallas, TX
71_Demon
Dallas, TX
Its a 383, bored .040, flat top pistons forged crank, 10.1 compression
-stock 452 heads
- MP .474 cam
- Headers
- Dual plane intake with 750 preform carb
- MSD ignition and Mallory uni-lite distributor.
- 3" all the way back
I'm just wanting to dial it in. Strictly street car. Hasn't seen the road in years so I'm sure it will need tuning. Always ran autolites, but they fouled out real quick. I've read resistor and non resistor plugs but not sure what the differences is. Any knowledge or suggestions appreciated.
'71 Demon 383 auto
'12 Ram 2500 6.7 Diesel
Re: Mild built 383 spark plug suggestion
[Re: lewtot184]
#1810915
04/24/15 01:33 PM
04/24/15 01:33 PM
71_Demon
Dallas, TX
I'm working on that. Bought a new carb with four coroner mixture screws. I had bad fuel contamination issue that I've addressed. It would plug the inlets of the carb. New fuel system from tank to carb. Just need a base line and a plug I can stick with while I get it where its good.
'71 Demon 383 auto
[Re: 71_Demon]
#1811100
04/24/15 07:23 PM
04/24/15 07:23 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
What carb. brand and part number is th new one? I would start with the stock jetting and put in a new set of Autolite 85 and set the ignition timing at 34 degrees total revved up beyond 4500 RPM, once I got the timing set I would check the timing at idle RPM, if it is less than 14 BTDC I would have the distributor recurved to get between 14 and 18 BTDC at idle and no more than 34 total revved up Proform brand new, 67200. I don't know or have I heard of any results on the Proform carbs, Sorry Let us know how that works out
[Re: 71_Demon]
#1813049
04/27/15 02:25 PM
04/27/15 02:25 PM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
-stock 452 heads FYI, A 383 with flat top pistons and stock 452 heads will have a lot less than 10:1 compression. More like 8.5:1. The domed KB400 piston would be close to 9:1 with that head. That said, any plug with close to a stock heat range should work.
[Re: GomangoCuda]
#1813696
04/28/15 03:56 AM
04/28/15 03:56 AM
RapidRobert
there've been some good plug threads in the past if you can retrieve them with the general concensus that quality of most of em has deteriorated (like most else). As said I'd figure out if it is gas or oil fouling & if gas then check the choke and or the AF ratio. Timing in the ballpark. For oil, new valve stem seals (if that is it) or maybe a rebuild (read "breakin secrets" at www.mototuneusa.com
