need location of map light dash switch.69 cuda #1808182
04/20/15 11:08 PM
04/20/15 11:08 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
where does the switch for the map light mount on the dash on a 69 barracuda ?
Re: need location of map light dash switch.69 cuda [Re: 2abodymcodes] #1808324
04/21/15 02:30 AM
04/21/15 02:30 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Interesting topic, because the 69 Barracuda did not have a listed map light option in the salesman's pocket guide here:
http://www.hamtramck-historical.com/dealerships/1969SalesmansPocketGuidesPlymouth-01.shtml
But a map light is shown fastened to the bottom of the IP about directly above the right side of the transmission hump in the factory service manual, page 8-73, with no clue about the switch.
So was the map light standard equipment? Or was it included with the optional light group A01 but not listed in the pocket guide?
My 69 Barracuda did not come with a map light nor was the car ordered with the light group option A01 (ash tray light, glove compartment light, ignition switch light, hood mounted turn indicators, trunk light, and headlights-on warning signal).
Re: need location of map light dash switch.69 cuda [Re: 2abodymcodes] #1808377
04/21/15 04:52 AM
04/21/15 04:52 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My 1968 has map light switch as part of the light group. It's on the bottom of the metal dash almost in line with the headlight switch. Hair to the right. That was 1968.
Re: need location of map light dash switch.69 cuda [Re: 2abodymcodes] #1810897
04/24/15 01:18 PM
04/24/15 01:18 PM
Georgia
1969383S Offline
1969383S  Offline
Georgia
See if this helps.
69 With A01 option.
Gerald
