Re: Reverse Light Harness hook up
[Re: MONC]
#1810819
04/24/15 11:36 AM
04/24/15 11:36 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
I had that harness on my '70 Bee. The pigtail goes to cavity Z of the headlight harness, and the dash light wire to the same on the inside bulkhead connection. The Violet ground wire bolts to the dash frame. The harness from the B/U light switch goes to the top left cavities of the wiper motor harness. Mine had a 2 wire pigtail coming out of cavites C and D, D being the hot wire I believe. The inside white wire is the power, it comes from the radio red connection, and the white w/ 2 black tracers runs to the body connector back to rear lamp harness.
[Re: Pynzo]
#1811288
04/25/15 12:14 AM
04/25/15 12:14 AM
Posts: 3,657 The Historic Hudson Valley
MONC
Hey thanks for the reply Pynzo. Sorry for the lag in reply, been a loooong day.
The wiring harness I have only has the black with white tracer with the jumper wire, another black wire spade connector and then the round connector with the 2 female connectors. No violet wire. I am a little confused by your description of how to hook up.
Mopar Or No Car
[Re: MONC]
#1811469
04/25/15 12:20 PM
04/25/15 12:20 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Got a reverse light harness for my 69 Charger. (I want the reverse light on the console to light up along with the reverse lights out back).
I've looked at a few wiring diagrams but sure how to hook it up (and don't want to fry anything in the process).
It's got a 2 blade connectors that jump between 2 of the bulkhead connections but not sure which ones, and 1 more blade connector. The other I think goes to the reverse light switch.
Pics of which bulk head connectors to attach the blade connector to, or which letters via the wiring diagram would be helpful.
Thanks in advance
Is the car an auto or a stick ? Safe to ASSuME you do not have a shop manual ?
[Re: JohnRR]
#1811485
04/25/15 12:57 PM
04/25/15 12:57 PM
MONC
Thanks for the clarification Pynzo. Here's a pic of the harness I have.
It's for a 4 speed car. I do have a shop manual, but I am finding this part of the wiring diagram hard to read John.
Mopar Or No Car
[Re: MONC]
#1811490
04/25/15 01:12 PM
04/25/15 01:12 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Where did you get that harness from? I need to replace mine and my original is not wrapped, just two wires fused together like a lamp cord.
[Re: MONC]
#1812242
04/26/15 12:15 PM
04/26/15 12:15 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
The grey connector would connect to a pigtail out of the Z cavity of the headlight harness most likely. I have the wire and terminals, I just need the rubber boot for the reverse switch and am having a devil of a time locating one.My oem harness is kinda crisp and is usable, but as I am doing a complete rewire I'd love to replace it. Anyone Know where to buy just the boot? Edit- I found that same harness at Brewers for $30. If I can't get the boot alone I'll get the harness from them. http://www.brewersperformance.com/proddetail.asp?prod=BLH
