What Yoke for a 73 Charger with a 489 8 3/4? #1810203
04/23/15 03:15 PM
04/23/15 03:15 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Can this be answered without pulling the driveshaft and measuring?
The car is a 1973 Charger 400-4bbl with a 489 8 3/4 rear. The ring/pinion isn't original but the driveshaft and yoke is. The rear was originally a 2.76 open diff FWIW.
What spline and u-joint size would this be or is that a roll of the dice?
Thanks!!!
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: cjskotni] #1810229
04/23/15 04:07 PM
04/23/15 04:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Should be a 7290...no need to pull the driveshaft to check, just measure across the yoke with calipers.
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: John_Kunkel] #1810539
04/23/15 10:43 PM
04/23/15 10:43 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Any idea on the spline count? 10 or 29?
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: cjskotni] #1810734
04/24/15 04:52 AM
04/24/15 04:52 AM
md
mopars4ever Offline
mopars4ever  Offline
md
it originally came with a 29 spline.
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: cjskotni] #1810801
04/24/15 11:16 AM
04/24/15 11:16 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Dangit. So why is that all the aftermarket 29 spline yokes seem to be in only 7960 or 1350 spicer u-joint??
The only yoke I can find that is 29 spline and 7960 u-joint is this one:
HERE
I am guessing this is more or less a stock replacement. I feel that if I am going to spend the money on a new yoke, I'd like to upgrade to a stronger one.
Any ideas if this one would stand up to occasional spirited street driving with a 499 stoker 727 auto in front of it??
Do the repair sleeves work or should I avoid them??
This is all due to a long running leak I have with my pinion seal which nobody seems to be able to fix. I am wondering if everybody is just incompetent where they can't do it right or maybe my yoke is grooved??
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: mopars4ever] #1810945
04/24/15 02:17 PM
04/24/15 02:17 PM
md
mopars4ever Offline
mopars4ever  Offline
md
3432487 is a 8 3/4 29 spline yoke 7290. brads nos shows online that they have one. mopar still sells them but you won`t like the price. make sure that is what you need before you order. some b bodies with 8 3/4 came with the small joint also but a 400 4bl should be a large joint. http://www.bradsnosparts.com/inventory/searchResults.asp
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: cjskotni] #1811489
04/25/15 01:11 PM
04/25/15 01:11 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I measured the outside of the yoke and subtracted 2x the thickness of the ends and come up with 2.6". This probably isn't super accurate as I did this with the car on the ground with me stretching to get the calipers over to the yoke from behind.
I am guessing the 2.6" is really 2.625 which would be 2 5/8" so 7290 u joint?
I also fiddled with the axle vent on the brake line tee and now there is a little oil that puked from there. I topped it off a few weeks ago (bottom of fill hole). Is this normal?
I see Dr. Diff has the 29 spline 7290 yoke here .
Will this be what I need? Also my current u-joint has straps...this one has u-bolts. Any issues there? I heard u-bolts are better?
Sorry to be an ignoramus but I have never put much thought into the differential/driveline since I had that re-done years ago.
Thanks! thumbs
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: cjskotni] #1811821
04/25/15 08:02 PM
04/25/15 08:02 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That must be a generic pic in that listing. You can see the yoke is clearly a 10 spline. And yes the fine spline yoke you need would use straps and bolts.
Re: What Yoke for a 73 Charger with a 489 8 3/4? [Re: cjskotni] #1811833
04/25/15 08:26 PM
04/25/15 08:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Measure the hex size of the pinion nut; if it's 1 1/8" it's 10-spline, if it's 1 1/4" or larger it's 29-spline.
